recommended supporting mods for 2.7 or 2.6 pulley
Old 03-14-2009, 06:01 PM
fastss25's Avatar
i have a 2.8 pulley looking to swap down to 2.7 prolly 2.6. i have intake, 60lb injectors, corsa cat back exhaust. what else would i need to be more reliable with these smaller pulleys????
Old 03-14-2009, 06:04 PM
Black SS/SC 06's Avatar
After market heat exchanger. Check out the one in my sig
Meth would help too
Old 03-14-2009, 06:05 PM
red06SC's Avatar
Dual pass w/ opt. B, meth, bigger H/E...
A lot of people make more power with the 2.8 setup.
I can't believe you're not even running an aftermarket H/E now...
Old 03-14-2009, 06:13 PM
rico's Avatar
dual pass, meth, extra bigger heat exchanger and yea i cant beleive u dont have alteast a dual pass or h.e with a 2.8 lol i bet ur heatsoaking huh i have a 2.8 and have dual pass and cobra h.e for now and wanting to get meth. but atleast get those cooling mods before u lower ur pulley size
Old 03-14-2009, 06:42 PM
fastss25's Avatar
no kr or heat soak problems so far been running this setup a year now. i run pretty rich though i had a buddy tune my stuff a year ago. i was wondering if i need a header or something else? so just the dual pass deal or a whole heat exchanger/ mean bigger core in the front of the car??? thanks for the replys so far guys!
Old 03-14-2009, 06:52 PM
Hockeyman's Avatar
you absolutely need meth, otherwise your IAT2s will be 160+ after a long pull.
Old 03-14-2009, 06:57 PM
Stiner's Avatar
header Downpipe and Heat exchanger
INFE's Avatar
I run a 2.7 with just dual pass and it runs fine as long as you dont beat the **** out of it when its 100 degrees out. I do have a full exhaust though.
Old 03-14-2009, 06:58 PM
fastss25's Avatar
does meth spray into the supercharger?? hurt the coating on the rotors?? i use to have a grand prix gtp and everyone complained about it hurting the supercharger rotors.
Old 03-14-2009, 07:00 PM
INFE's Avatar
it does not hurt the rotors but it distroys the bearings
Old 03-14-2009, 07:01 PM
R&C_rallySS's Avatar
Another over spin your Eaton thread?
Old 03-14-2009, 07:05 PM
INFE's Avatar
lol to someone that dont know what there talking out
Old 03-14-2009, 07:11 PM
Umm yes he does
There are plenty of threads about going below a 2.8 pulley.
This is straight from EATON...........
Reducing the size of the pulley increases both response time and maximum RPM of the supercharger. The stock pulley sets the M-62 blower at maximum efficiency and reducing pulley sizes does reduce efficiency. Porting the supercharger and using supporting heat-reduction modifications can help negate these negative effects of increasing boost by using the smaller pulley. While they do help reduce the negative effects of increased IAT's, these supporting modifications can only help so much. The increased IAT's produced by using any smaller than a 2.8" pulley will most likely not be able to be reversed by these supporting modifications. It is not recommended to run pulleys smaller than 2.8”; however, all cooling modifications with methanol injection may make it possible to see benefits from a 2.7” pulley. 2.5” and 2.6” pulleys bring the supercharger way past its maximum RPM range and will significantly reduce the life of the supercharger. Keep that in mind.
Last edited by Black SS/SC 06; 03-14-2009 at 07:11 PM. Reason: Automerged Doublepost
Bigdaddyruffluv (01-28-2016)
Old 03-14-2009, 07:15 PM
06' SS2SS's Avatar
Good post.
Old 03-14-2009, 07:17 PM
rico's Avatar
trust me with the cooling mods on the 2.8 u will be gaining more power with what u have right now. reduced heat = more hp able to be made/gained
Old 03-14-2009, 07:22 PM
INFE's Avatar
yea i have seen that thread. You guys have fun with your stage 2 and 3.0 pulleys, you will never see the potential of the car. Im out
Old 03-14-2009, 07:24 PM
hatrickstu's Avatar
stumod. get it.
Old 03-14-2009, 07:25 PM
Originally Posted by Black SS/SC 06
Umm yes he does
OWNED! Nice post. I don't give a flying **** if someone says I don't know what I'm talking about. I ran a 14.2 @ 100mph stock. The only cobalt member in a stock SS/SC to hit 100mph in the 1/4th mile. I have the slips to prove it, and I'm on the list for fastest stock SS/SC. Then I went and ran mid 13s with stage II pulley. Damn little kids on this site telling me I don't know what I'm talking about when my custom built Syclone can put down x4 wheel horse power then a cobalt. Check my join dates children.
Originally Posted by hatrickstu
stumod. get it.
lawlz
Old 03-14-2009, 07:27 PM
13.6 @ 108 mph with stage II, intake, and exhaust only. On the stock tires. A 2.8 is as small as you want to go. With meth, H/E, dual pass, and the correct little tricks you should be able to go high 12s.
Old 03-14-2009, 07:28 PM
hatrickstu's Avatar
13.6 @ 108 mph with stage II, intake, and exhaust only. On the stock tires. A 2.8 is as small as you want to go. With meth, H/E, dual pass, and the correct little tricks you should be able to go mid 12s.
fixed
Old 03-14-2009, 07:29 PM
rico's Avatar
haha stu good one. and ya i want the stumod !!
Old 03-14-2009, 07:33 PM
Stiner's Avatar
What do 1/4 mile times and joined date have to do with what you know?
The fastest times and hp have been done on the small pulleys with good tunes most without any cooling mods whatsoever. I'm not saying cooling mods are useless(although I do feel they are very overrated on this site) I'm just saying with a good tuner 2.7>2.8
Old 03-14-2009, 07:35 PM
hatrickstu's Avatar
oh yea? might wanna do some searching
i heard of a certain 2.85 car running high 12's (now mid 12's) on a 2.85. hell i think it even trapped 113 once
Old 03-14-2009, 07:36 PM
Stiner's Avatar
I know your time stu its plastered allover the site ha
Quick Reply: recommended supporting mods for 2.7 or 2.6 pulley
