Redline problem
Redline problem
Earlier today I went on the 202 bypass and decided to test the limits of the bolt sc. I floored it and redlined the car in 4th gear. The engine light went on and a sign came up that said "reducing engine power". The car made a weird noise and was bucking when i was driving. I pulled over turned the car off. I started it back up the sound was gone and the car drove fine. The only thing is the engine light is still on. Did I **** something up or will it go away eventually?
The light came on when you hit the limiter, or during the pull? I saw something similar on a friends car, it turned out to be a bad Cam position sensor. Need to get the code read.
Its just a safety feature so you dont blow up
I had the same thing happen when I accidentally down shifted into 2nd instead of shifting into 4th
, it came on real quick but I caught it and popped it back into neutral before it fucked anything up.
Sep 28, 2015 12:51 PM
