Reduced Engine Power
Mods
GM stage 2
2.90
i have the msg Reduced Engine Power ...... what would this be ?
P2101 throttle acculator control motor circuit
spark plugs are good
GM stage 2
2.90
ok reseated the battery and CEL is on sounds like WRX
i'm gonna look the sensor up now as well
thanks
thanks
I'm gonna go out on a limb and say it's no plug and it's def not #4. Mine made the same sound when my plug was loose. I tell you what though, was enough to make me a little worried.
the TB plug?
i have no idea i look at it and looks to be ok not lose
if i cont the car on the computer would it show what up ,,,my friend has it at home?
Ok, it's simple, you're gonna have to take the valve cover off. It's 4 star bit screws you have to take out. Then the plate comes right off. After that you have to undo the 4 connectors for the spark plus. You will need like a 10" extension for a ratchet to get to them though. I forgot what size they, 3/4 or 5/8 I think.
Mine did this. Check that connection under the TB. By checking the connection, I mean pull the TB from the car and check the pins inside the connector. Mine actually had 2 bent pins and the plug wasn't seating properly on them, causing the CEL and reduced power. I bent the pins back, CAREFULLY plugged the connector back in, and all was well. Then, if that doesn't work, clean the SCIP and MAF sensors with MAF cleaner, clear the code, and try again. I had a problem with my SCIP and MAF not being in sync due to dirt, and that too threw a CEL and reduced power under load. If that doesn't solve it then check the plugs. It's most likely not a plug but you never know, especially with the cold weather.
Mine did this. Check that connection under the TB. If that doesn't work, clean the SCIP and MAF sensors with MAF cleaner, clear the code, and try again. If that doesn't solve it then check the plugs. It's most likely not a plug but you never know, especially with the cold weather.
spark plugs are good clean
any ideas ?
thanks
here it is car sounds just like my car WRX and same code
http://www.youtube.com/watch?v=KRrh7y4zIsw
any ideas ?
thanks
car fixed
today i put the stock intake system back and some paper was in the intake pipe which i did not know about and it got stuck in to the TB ....TB is cleaned and car runs like brand new
thank god
thanks ppl
thank god
thanks ppl
