Removing Bottom Belt Tensioner Bolt
Old Dec 11, 2013 | 06:55 PM
kobe77's Avatar
ok so my problems continue with this ******* tensioner. from frustration i fucked the tensioner pulley which made me sort of happy because im sick of this stripped tensioner! buying a new tensioner, went to take the stocker off today and cant get to the bottom bolt which is a tight clearance from the engine bay sidewall. anyone have a good alerrnative to getting to the little sucker? i know itll be simple once i get a wrench on it but i need a good way to get a wrench in there. thanks
Old Dec 11, 2013 | 06:57 PM
TStone's Avatar
I have absolutely no problem getting to it, but my hands are smaller than most peoples. Get a buddy with small hands... I had no problem getting a wrench on it.
Old Dec 11, 2013 | 06:58 PM
kobe77's Avatar
what wrench did u use? i used a baby wrench with a 1/2. is that the size of the bolt? looked accurate from eyeballing it
Old Dec 11, 2013 | 07:05 PM
kobe77's Avatar
this is for the lsj btw. forgot to include that
Old Dec 11, 2013 | 07:06 PM
TStone's Avatar
I believe I used a 13mm.. 1/2 is just baaaarely smaller than a 13mm so if a 1/2" fits it, then use that.
Old Dec 11, 2013 | 07:07 PM
blueLNFftw's Avatar
Isn't this the bolts that you can get to with an extension through a notch in the frame?
Old Dec 11, 2013 | 07:10 PM
TStone's Avatar
I do believe so actually..
Old Dec 11, 2013 | 07:29 PM
kobe77's Avatar
i know u can get the crankshaft bolt through taking off the panels by the fender. can this work for the tensioner as well?
Old Dec 11, 2013 | 07:30 PM
TStone's Avatar
No. but there is a little hole in the frame rail that you can get a socket and extension through.. you might have to raise (or lower, i don't remember) the engine but it will allow easy access.
P.S.!!!!! Make sure you use a magnet or something. The bolt very well could drop into the frame!!!!!!!!!! You have been warned.
Old Dec 11, 2013 | 07:35 PM
kobe77's Avatar
already had my magnet handy today haha. but ok cool ill try this. just jack the engine to releive a bit of tension? ill give this a go tomorrow
Old Dec 11, 2013 | 07:45 PM
TStone's Avatar
yeahhh. but if the engien has to come down, then you'll have to take out the 3 bolts in the left engine mount. BUT MAKE SURE YOU HAVE A JACK UNDER THE ENGINE WHEN YOU TAKE THEM OUT.
DarrenGC
Dec 24, 2021 01:55 PM
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
cw383
Sep 30, 2015 12:41 AM
