Restriction?
Old Jul 26, 2010 | 09:58 PM
Perfect.disguise's Avatar
Restriction?
Have a 2.8 setup with the rest of the bolt-ons. Anyways I have the Vibrant combo and the cat went out in it so I just had my OEM welded in a while back. Is the OEM cat in it that restrictive..would it be worth it to gut it or get a sleeve welded in?
Old Jul 26, 2010 | 10:00 PM
ecot3c inside's Avatar
I would say go catless, but sounds like you have emissions eh?
Old Jul 26, 2010 | 10:01 PM
No, no emissions. Just the standard state insp in my area that you can get at any garage mechanic.
Old Jul 26, 2010 | 10:03 PM
sounds like a good excuse to just get a straight pipe welded in there! If the garbage mechanic says its okay
Old Jul 26, 2010 | 10:09 PM
Just curious if it would effect my mid range and peak HP much and it I will loose some TQ.
Old Jul 27, 2010 | 01:00 PM
Old Jul 27, 2010 | 01:29 PM
Stone629's Avatar
You will probably lose some torque down low. Might pay to go with a better flowing cat instead. I don't think the OEM cat is all that restrictive, but it's not the best either. I would take advantage of that header and flow as freely as possible without losing too much exhaust velocity.
Old Jul 27, 2010 | 01:58 PM
Staged07SS's Avatar
Administrator
Administrator
The OEM cat is a high-flo unit. You will not notice any loss in power. I went from a ZZP 3" downpipe with High-flo cat back to my OEM 2.75" downpipe, and did not notice a change other than some low end power that I got back due to the slightly smaller piping.
Turbo Johnny
Feb 21, 2019 09:41 AM
NJHK
Tuning
Nov 4, 2007 07:30 PM
D4u2s0t
Apr 26, 2007 05:37 PM
Coors
Apr 8, 2007 08:24 PM
NJHK
Dec 10, 2006 08:32 PM
