Rev Limiter
Rev Limiter
Ok you hit about 7000rpm on a stage 2 SS/SC and it falls flat on its face. This is because the computer restricts injection right? So can that actually hurt the engine? Your not in neutral reving the engine to redline with no where for the power to go, but youre just pushing it to the point where gm says no... is that damaging to the engine?
Noob Question i know...
I used to be a ford mustang gt guy... i just cant help it.
If you hit it when driving your not going to hurt your car. If you drive around with it bouncing off the limiter your going to have an issue, haha.
Just don't hit it and there won't be a problem
Come on thats no fun. the car pulls the best at high rpms it just makes you want to never shift in 2 and 3... 1st gear sucks ass. Stage 2 made 1st gear a little longer atleast from what i can tell but 2 and 3 is where its at. Seriously nothing bad will happen though... dont want to warp pistons or anything
Originally Posted by Blown 4-banger
iv noticed that my rev limiter comes on almost before 6500 in first, and a little after in second and third.
HTH
WopOnTour
Originally Posted by WopOnTour
Which is the normal rev limiter unless you have one of the Stage kits that reflashed the PCM to raise the limiter to 7000.
HTH
WopOnTour
HTH
WopOnTour
Originally Posted by IonNinja
aren't these reflashing enforcing the rev limiter the same way they are stock? if so I don't see why it would ever be an issue.
Wop
Iceberg
Sep 29, 2015 12:33 PM
z28addiction
Sep 28, 2015 12:03 AM
