rev it up kit installed PROBLEM
need help
installed revitup kit and i went down in psi?
and i have a check engine light
but car is running perfectly
i went from 12.5 too like 10 and it wont go any higher and i have the boost bypass mod right now
Did you take the S/C off to install the pulley? If so, you may have a vacuum leak if you didn't put the S/C back on correctly
Check your engine code and see what it is.
Also, Your belt could be slipping
If you are using the factory PCM controlled boost gauge, it WON'T read correctly!
Mine did the same thing, sometimes it would bounce all around.
You need a mechanical boost gauge if you want the correct reading. Hope this helps before you go tearing the car apart. You prob have it installed correctly.
-Travis
-Travis
-Travis
-Travis
Originally Posted by Darksun280
but get this i told him to unplug the box and run stock pcm just to see and the boost guage would read at all if it was even hitting boost since it should cause i had the boostbypass mod on it. you could feel the sudden rush in power though when the guage jumped from 10 psi to 15 finally so it might no be just the guage.
yeah so im running the car without the tuner box in and im getting 16 psi
im really pissed though cause i figured out that the probelm was that box
ooo well
Originally Posted by zinner
Rev it up changes the MAP signal so the PCM thinks your getting less boost than you truely are.
Cptnslo
Sep 24, 2015 09:32 AM
