Review: ZZP BRFS
Old Aug 27, 2010 | 06:18 PM
  #51
csementuh's Avatar
Originally Posted by skatin_boarding
I got mine set at 58psi for base now and its idling really good. I am having problems without the little plastic block off adaptor when my tank is under half full. looks like Im going to have to drop the tank again. Must cause to much of a ruckus in the canister for the pump to get the fuel when less than half ful
Glad to hear it's working despite the disc. Call ZZP lol. I'm going to set mine to 58psi as well. What does it idle at with the vacuum corrected -20 (or whatever vacuum your car idles at)? 38psi?, or is the 1:1 ratio only in boost? What are you using to measure fuel pressure?
Old Aug 27, 2010 | 07:29 PM
  #52
skatin_boarding's Avatar
I used just a basic fuel pressure gauge on the fuel rail valve. You know im not sure what it is with the vac line hooked up. I will find out later tonight for you. I think it only pulls 9 pounds in vacuum.
Old Aug 27, 2010 | 07:31 PM
  #53
WSFrazier's Avatar
Yeah, I think that was my problem too. I still don't understand why, cause fuel is being dumped into the canister either way... I think it's cause fuel isn't getting down the line/hose that goes to the internal pickup at bottom/inside of canister. Obviously with the tank completely full the canister is filled all the time.
The new ZZP regulator is okay, problems kind of are fixed now. Fuel is being pulled correctly at idle, and fuel trims are staying dead on too where I have MAF tuned. Before it would randomly be +/- 25% at any given time.
But now I am still going way over 100% IDC @ 6200 and but its tappering off to lean instead of hitting a dead fuel cut. So now it looks like my 2005 shitty ass pump is already at its limits.
The more I add fuel in MAF, the sooner in the RPM range it goes lean, everything points to pump now.
Skatin, since you have the same pump/canister as me, let me know how your pump seems to do.
Old Aug 27, 2010 | 08:06 PM
  #54
y2kzman's Avatar
Looks like I need to contact zzp to get the block off disc. I am working on incorporating a bosch 44 pump inline in my setup I will let you know how it goes.
Old Aug 27, 2010 | 08:09 PM
  #55
WSFrazier's Avatar
I actually have an in-line pump available to me that would easily take care of my problems.
But I really don't have room to put it anywhere before the regulator with the ZZP kit.
BTW, all the disc is made of is plastic cut into a circle. You can easily make something yourself. Let me post pictures...
Old Aug 27, 2010 | 08:25 PM
  #56
Have you tried to upping your pressure anymore? I havent tried my 2.75 yet. Still tuning on the 2.85 and barely getting to 90 idc and I was over 100 before the brfps.
Old Aug 27, 2010 | 08:27 PM
  #57
y2kzman's Avatar
I can make that. I hope I still have the retainer clip. Thanks for the pics
Old Aug 27, 2010 | 08:30 PM
  #58
WSFrazier's Avatar
From what i have seen and some math. 58 base with 22 more psi under boost should be plenty. 2.75 isnt that much more. Im hitting 120 idc at 6600 ish.
Old Aug 27, 2010 | 08:31 PM
  #59
whats your afr? do you have exhaust?
Old Aug 27, 2010 | 08:35 PM
  #60
WSFrazier's Avatar
Soon as I hit 100 IDC, it starts going from low 12s to high 13s near 7k. These are gas afr's.
Stock exhaust manifold with catless 2.5 downpipe and gmpp sport. Header is next on my list but want a clutch first.
The thing is, as you increase fuel pressure, you decrease the pumps flow. So I don't want to run a 70psi base. Nor should I need too. With the way tuning is acting, it points to the pump.
Old Aug 27, 2010 | 08:46 PM
  #61
Yes I am going to have to agree with you.
This is all new to me so you have to bare with me as I learn the basics of fuel systems. So when you increase your pressure you lose flow from the pump. Do you happen to have the fpr?
Now say you go out and buy a better pump do you install it and keep the pressure the same? lower it? raise it?
Old Aug 28, 2010 | 10:01 AM
  #62
So I started running into problems last night tuning. I will randomly go lean and have a fuel cut. Weird thing is, is that my battery light comes on and the car practically shuts off. Happened three times and dont want it to happen again.
Are these the problems you were running into? I know Im not out of fuel because I have gotten to redline. And yes the regulator lags a little on idle when you tap the gas.
Old Aug 28, 2010 | 10:47 AM
  #63
WSFrazier's Avatar
Is your tank getting low when this happens?
I really hate these 05 cars. I'm heading to Summit now to pick up a high pressure walbro pump. I think ZZP has an aftermarket pump that out flows stock and walbro, but I don't feel like waiting until next week.
This will now be my 5th or 6th time dropping the tank, lost count.
Old Aug 28, 2010 | 12:09 PM
  #64
No my tank is full.
Old Aug 28, 2010 | 08:54 PM
  #65
BlackMagic's Avatar
could it possibly be your fuel filter?
Old Aug 28, 2010 | 09:23 PM
  #66
Maybe but I wouldnt suspect that.
Old Aug 28, 2010 | 10:29 PM
  #67
WSFrazier's Avatar
My fuel filter is brand new, less then 1k on it probably.
I just finished installing my Walbro GSS342 that I picked up at Summit today. Going to go test the car out now. Better of fixed my issues.
Old Aug 29, 2010 | 12:40 AM
  #68
csementuh's Avatar
Glad to hear you got your new pump in.
Soo.. Is this a problem with the 05' fuel pump or all of the year pumps on a small pulley TVS? If I have to do a pump too, I'm probably not going to do E85.
Old Aug 29, 2010 | 02:45 AM
  #69
WSFrazier's Avatar
It's an 05 thing. All the pumps are 2006+ cars actually outflow or are atleast even with the Walbro's. From what I have seen anyway.
2005's have a smaller pump than the rest, and that was my problem.
Got the new pump in with some persuasion. All my problems are cured. With a 58psi base, I see about 92% IDC at 7300RPM. And that's commanding a 7.4 AFR. I have it rich up at top.
Love the feeling of 25* timing all the way to 7300 E85 and 2.7" TVS.
Old Aug 29, 2010 | 09:25 AM
  #70
So there is one of my problems. Ill have to pick that one up too. Im guessing the pump is p&p?
Old Aug 29, 2010 | 11:07 AM
  #71
WSFrazier's Avatar
Not exactly plug and play. Some dremeling is needed to make the pump physically fit. But that's the case with all the cobalts/ions.
The 2004/2005 pumps use a different harness. So you will need to cut that one and use an actual Walbro pump pigtail (which I didn't have). Or just use quick connect/spade connectors that you can find at any parts store, they fit perfectly.
Old Aug 29, 2010 | 11:15 AM
  #72
csementuh's Avatar
I'm really glad to hear you got the car running well! Kinda sucks though that you had to buy another part. I can only imagine how nice that small pulley and E85 feels!
Old Aug 29, 2010 | 07:45 PM
  #73
Thanks for the info. Ill order that pump tonight.
Old Aug 30, 2010 | 10:01 AM
  #74
csementuh's Avatar
Ordered my BRFPS kit, so I'll be looking forward to this fun and excitement pretty soon lol.
Any advice on dropping the fuel tank? Quick howto? I'd imagine go as low on gas as possible and get the rear of the car high in the air would be a good start. Other than that I've never looked at it enough to see which bolts need removed and what not?
Old Aug 30, 2010 | 10:08 AM
  #75
rico's Avatar
yall should of done a very detailed how to with pics
