is this right. 10psi stock
Old Feb 22, 2007 | 07:02 AM
Psi Phreak's Avatar
like the title says I have 06 ss/sc 2k and only hit 10psi
Old Feb 22, 2007 | 07:07 AM
1gmfanatik's Avatar
Kinda low..Weather may be a factor have you ever hit higher?? 2K mean the amount of miles you have?? Otherwise I might say that she hasn't fully broken in yet to allow for the full boost..Not too sure though
Old Feb 22, 2007 | 07:11 AM
A-Town's Avatar
Or you could have a slightly off gauge? After braken in your car around maybe like 3/4k take it to the deadler to explain to then your situation.
Old Feb 22, 2007 | 07:16 AM
DTM2188's Avatar
Like said above, maybe its not broken in yet. you should be seeing 12.5 psi stock.
Old Feb 22, 2007 | 07:20 AM
blown06's Avatar
either your gauge is off or something is not right, I was hitting 12.5 with no problems.
Old Feb 22, 2007 | 07:36 AM
BlackyK's Avatar
I hit 12.5 with no problems.
Old Feb 22, 2007 | 10:32 AM
L.P.'s Avatar
On the stock pulley it is hard to pull the 12.5 out it seems, you have to be near the upper rpms to see it. I had the same problem at first PSI freak, I thought I wasn't hitting 12.5, but I got somebody to watch the gauge for me and I was.
Old Feb 22, 2007 | 10:34 AM
Pyros777's Avatar
Beat on it.
Mine opened up at 1035mi, but also coincidentally after my first hard launch and couple races from a dig.
Old Feb 22, 2007 | 10:38 AM
vtecduster's Avatar
get her up to 5k rpms at WOT in third. You'll hit the 12's.
Old Feb 22, 2007 | 11:25 AM
RaineMan's Avatar
That's what you've gotta do... in 2nd it is hard to actually see max stock boost... you'll have to be in 3rd on the freeway or something... just lay on her... it'll get up there. You'll have to be at 5000 or so for those last few PSI to show.
Stage 2 is the same way... we'll jump up to 12-13 pretty fast... but to get the full 15 you need to wind out 3rd...
Old Feb 22, 2007 | 11:47 AM
RedlineBrian's Avatar
Give it time it happend to me too. You'll get it.
Old Feb 22, 2007 | 11:54 AM
martinsmu's Avatar
Mine stock/new went right to 12.5 when I reved her up.Each car is different. Give her a month...
Old Feb 22, 2007 | 12:23 PM
DaREDss's Avatar
i thought u didnt hit full boost till 4k
Old Feb 22, 2007 | 12:41 PM
Psykostevo's Avatar
Both of mine only registered 10psi stock, and they were slower than they should have been.
Old Feb 22, 2007 | 12:54 PM
chipsgt's Avatar
I wasnt able to see full boost until around 3,000 miles.
Like it was said above, hit about 5 grand in third gear and then look at the guage.
Make sure you maintain full throttle pressure when doing it.
Meaning, dont take your foot off the gas and then put it back down.
Old Feb 22, 2007 | 01:26 PM
Boost Fr33k's Avatar
i hit 10psi in first gear then after that 13. idk
Old Feb 22, 2007 | 02:43 PM
neb07ss/sc's Avatar
my 2007 is doing the same thing, only 10lbs of boost... but i only have 200 miles on it
Old Feb 22, 2007 | 03:00 PM
Rodimus_Prime's Avatar
im getting the full 12.5 i only have 3800 miles on my 07
Old Feb 22, 2007 | 03:06 PM
ReMz's Avatar
what is your altitude? that is a major factor. i only saw 10psi (maybe less) at an elevation of 6,000ft while i was stock. you should see full boost in 1st and 2nd if you are keeping a sharp eye on the gauge. otherwise, do as other's have said and let 'er rip in 3rd.
Old Feb 22, 2007 | 03:16 PM
M-Dub's Avatar
You just have to wind her out! WHen I was stock and put on my K&N I went from 12.5 to almost 14 and then sometimes I hit 14.5-15 when it was like 2 degree's in the morning here! So it's prolly okay you just aren't pushing her hard enough to get full boost!
Old Feb 22, 2007 | 06:30 PM
Psi Phreak's Avatar
this may be it
My cat converter is clogged
Old Feb 22, 2007 | 07:42 PM
saunders1986's Avatar
whats 12.5 psi in kpa....... lol my new 07 wont go past 80kpa
Old Feb 22, 2007 | 07:43 PM
pmerritt's Avatar
NO.....if the cat is clogged then the gases cannot escape and pressure builds, in other words, he'd be seeing more boost than he should.
Old Feb 22, 2007 | 07:58 PM
if your getting 80kpa your not even in boost, 105 is atmosphere, 12psi would be closer to 190kpa
Old Feb 22, 2007 | 08:44 PM
eurochevy's Avatar
saunders1986 whats 12.5 psi in kpa....... lol my new 07 wont go past 80kpa
ya same with mine ...im at 3,000 km's and only boosting 10 psi well close to 11.. (80 kpa)
Rodimus_Prime if your getting 80kpa your not even in boost, 105 is atmosphere, 12psi would be closer to 190kpa
btw dude maybe u should check sum conversion scales or something....190kpa is like 27.56 psi LOL that would b freaken amazing if that was true lol if it was then wow these cobalts do more than the ones hahahah
