Road racing boost problem
Old Nov 7, 2009 | 03:19 PM
fastcav29's Avatar
Has anyone else put their SS/SC on a road course and after about 5 laps had the boost drop to about 2 psi with no DTC or mil . This happened to me at Hallett racing circut every time I went out. I could pull into the hot pits turn off the eng restart it and smoke the tires while going back on track but less than a lap latter it would pull all my boost. The engine never went over 207 and my scan tool showed nothing obvious in the O2 or cat . I am not to concerened, as I won't do this very often and I have never had this problem on the street and I like to here the screem as much as anybody. Just curious if bumping 12psi for a long time causes the OEM burn to pull the boost out?
Old Nov 7, 2009 | 03:20 PM
slowswap's Avatar
What's your IAT2's? If they get to hot it will pull boost.
Old Nov 7, 2009 | 03:49 PM
Dennisscars's Avatar
Yeah ^ that.. It'll go into boost unload at something like 210*F IAT2. If your I/C system is not top notch it get hot like a **** that many WFO's in a short period..
Coolant temp does not associate with I/C temps but at 207 engine temp your working the car.
Was just there in Sept..
Old Nov 7, 2009 | 04:00 PM
Pyros777's Avatar
Yeah definitely sounds like your IAT2 temps are skyrocketing. Time for some cooling mods!
Old Nov 7, 2009 | 04:13 PM
krishansheanh's Avatar
ariel atom. you're lucky
Old Nov 7, 2009 | 08:17 PM
alleycat58's Avatar
Never had a problem with mine on the road course, but I concur with the IAT2 theory.
Old Nov 8, 2009 | 02:13 PM
fastcav29's Avatar
Didn't think about that......thanks everybody that makes me feel better and makes a lot of sense. If my wife dosn't watch me close I'll have a cage and a Kirkey in the screemen meme that was a blast!
Old Nov 8, 2009 | 02:33 PM
Karlen89's Avatar
Get a heat exchanger!
Old Nov 14, 2009 | 09:39 AM
fastcav29's Avatar
No IAT 2
My cheap A-- Actron Scan tool dosn't show a 2nd IAT sensor is that normal? Do I need to get HP tuner to see this? I have a 2006 SS/SC.
Old Nov 14, 2009 | 10:16 AM
red06SC's Avatar
IC pump is gone, 100% positive.
Start the car and make sure your coolant is flowing..just in case.
Old Nov 14, 2009 | 11:44 AM
Jn2's Avatar
Jn2
Hpt and interceptor gauges display iat2's. And it sounds like u need cooling mods. Dual pass and a secondary h/e will def help you out.
RaginChopsuey
Oct 27, 2015 01:27 PM
717ssbalt
Oct 2, 2015 04:01 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
