rods
Old Mar 30, 2008 | 07:53 PM
StevesBlack06's Avatar
rods
who makes rods for the 2.0LSJ? any ideas? thanks in advance.
Old Mar 30, 2008 | 08:09 PM
2K5SS/SC?'s Avatar
I think Crower and someone else makes them. Why do you need them anyhow? Our stock rods are good for about 500hp anyhow. Hell, Paul just made 411whp on a stock engine with his turbo setup for that matter.
Old Mar 31, 2008 | 04:27 PM
i was told the stockers are only good for like 350. hmmm. interesting.
Old Mar 31, 2008 | 04:32 PM
Pully Police's Avatar
You should start to think about upgrading at about 400hp. At 450hp, you will NEED to upgrade
BTW, this is from the build book
And....if you are going to change the pistons - you may as well chnge out the rods too - it is actually less work than having to swap all the parts over to the stock rods and reinstall. You just have to make sure that the rods are all the same weight, will accept the old bushings from the big end, and will have the proper clearance (side play) once installed.
Last edited by Pully Police; Mar 31, 2008 at 04:32 PM. Reason: Automerged Doublepost
Old Mar 31, 2008 | 04:37 PM
well i got my pistons and i cant find rods for the life of me. i figure ill be in the ballpark of 300-330whp when i put her back together this year. but i figured since i had it apart if replace em now. because next year shes gonna be even meaner.
Old Mar 31, 2008 | 04:42 PM
Crower makes rods for our engines - www.crower.com download the catalogue and you will see that they have a direct fit for the 2.2 and LSJ.
Eagle makes rods too - might want to check their site also www.eaglerod.com
hope that helps!
Old Mar 31, 2008 | 04:58 PM
i checked eagle and didnt see them. i didnt look too hard with crower but ill def have to give them a shout. thanks
Old Mar 31, 2008 | 05:02 PM
eagle - http://www.eaglerod.com/products/Che...r%20chevy.html
crower - download the pdf for the rods (2008 version) - the 2.0/2.2 rods are located under the "sport compact" section in the pdf.
Old Mar 31, 2008 | 05:13 PM
so the 2.2 and the 2.0 rods are the same?
Old Mar 31, 2008 | 05:48 PM
Yes. The crank is different.
The stock rods are the same dimensions - the LSJ rods are forged and alot stronger than the 2.2 rods - which are cast.
Last edited by Pully Police; Mar 31, 2008 at 05:48 PM. Reason: Automerged Doublepost
Old Mar 31, 2008 | 05:52 PM
2K5SS/SC?'s Avatar
I thought the rods were different due to the piston pin size. You might want to check into that. Also the build book for the 2.2 has rods being replaced after 250hp, the LSJ build book says the rods are good for around 500 like I stated. Paul is at 411whp on his stock bottom end right now, so I do believe they are pretty damn strong!
Old Mar 31, 2008 | 06:02 PM
very nice thats less $ i have to spend! time for cams!
Yes..you are right about the piston pin, I believe. BUT it is a moot point if you are getting new rods *and* pistons.
You are correct - The new L61 book says to upgrade to the LSJ rods at 250hp...and to upgrade to aftermarket rods at 400hp. I am not sure how much of a safety margin is assumed with the build book. But I would bet money that if you go over 450hp on the LSJ rods, you are asking for trouble. On that note...you risk sleeve damage as well at those power levels.
Here is the rule with LSJ's: If you are planning 450BHP or more, you WILL REQUIRE upgraded pistons, rods, and sleeves on the bottom end...period.
Old Mar 31, 2008 | 06:31 PM
well looks like ill stay on my factory rods for now. maybe ill tear it down again next year if i still have it. thanks everyone for all of your help
Old Mar 31, 2008 | 06:59 PM
Karo's Avatar
We are currently working with a Rod Manufacture to get some Rods made for the LSJ Engines. We should have our first batch of LSJ Rods within the next 2 months to start shipping out. I will do my best to post some pictures of the Prototype LSJ Rod soon as I get one in my hands. The Rods will also come with ARP Hardware as well.
Solaris99
28
Mar 15, 2017 01:22 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
