rods and piston installation question
Old Feb 8, 2010 | 02:31 PM
Kozy's Avatar
Hey everyone, i just need a little help i cant seem to find this even in the Haynes manual.
when putting the pistons and rods back together, the f on the pistons goes toward the timing chain but which way to the rods face? the only thing i notice on the rods is a little bump on the crank side end of the rod. anyone who had put these back together can you please tell me how the rods go or if it even matters
thanks alot
Old Feb 8, 2010 | 03:12 PM
hungryhip-ccp's Avatar
well when you were disassembling you should have marked the rod caps silly!
are you using new rod bearings? if so it don't matter, if you are not then you would want them to go back exactly the way they came out. meaning 1 goes back to 1, 2 goes back to 2 and facing the right way.
also make sure you have all the caps going on the right rod, they are a "crack capped rod" meaning they must go back on the right piece like a puzzle
Old Feb 8, 2010 | 03:51 PM
Kozy's Avatar
yeah lol i know marking would have been great unfortunately i cant do it now lol... but yes i have new rod bearings and i also figured out which cap goes with which rod.
so what your saying is as long as the pistons go f towards front that little bump on the bottom of the rod doesnt matter?
Old Feb 8, 2010 | 03:56 PM
ralliartist's Avatar
for future reference, don't take ANYTHING apart EVER on your engine with out marking it. ESPECIALLY internals.
Old Feb 8, 2010 | 04:30 PM
in my build pics it looks like the bump was going towards the reluctor ring on the big end of the crank towards #4 cyl and the F on the pistons go towards #1 cyl
Cefaln452's Avatar
F goes towards number one cylinder
Old Feb 8, 2010 | 05:57 PM
Kozy's Avatar
this is definitely helpful.. thanks alot for this!!
Old Feb 8, 2010 | 07:09 PM
no prob, remember the rod cap bolts, cam gear bolts, crank pulley bolt, headbolts and mainbolts are NOT re usable.
And this is your best friend! http://gmtunersource.com/media/racer...LSJ_Chap_6.pdf
ineedacobaltss
Nov 7, 2015 02:25 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
justinchinn
Oct 2, 2015 12:18 PM
Stuff
Oct 1, 2015 05:47 PM
