Rotor Direction?
Rotor Direction?
I just purchased Slotted/Cross Drilled rotors online and had them installed at my dealership. It looks as if the front 2 rotors are spinning the wrong direction/swapped. Will this affect stopping distance/brake bite? Are certain rotors assimetric? Thanks in advance.
Yep, for sure. Pics will be up in a couple minutes im just gonna shoot this post out real quick to let you guys know. I just ran out to shoot pics, cars a bit dirty, sorry about that. Just made a 60 mile treck back home country road... bugs... pete dirt... bad news... Just did the rotors and the new tires BFG Gforce Sports 235/40/ZR18's baby, wider is better. 235's all around are just as wide as the rears on my Camaro, just figured that out yesterday... pretty nuts. Anyways, thanks for the input and do you think the front two rotors suposedly spinning backwards does much harm to brake bite?
this is not correct. you have it backwards. curcing inwards is adding heat, which is against the whole reason of having slotted rotors
your both wrong. ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhh
mine came labeled from GM L and R
they start from the inside hub and go outward towards the rear of the car
that is how the last 3 sets of slotted rotors hhave been on all my cars
similar concept as directional tires
As you can see the front rotors are, in my mind spinning backwards, itll be on a lift today.
Theyre on photobucket.com links are as follow, one link should allow you to see all but im gonna post all links anyway just in case.
http://i42.photobucket.com/albums/e3...0709081345.jpg
http://i42.photobucket.com/albums/e3...709081345a.jpg
http://i42.photobucket.com/albums/e3...709081345b.jpg
http://i42.photobucket.com/albums/e3...709081345c.jpg
http://i42.photobucket.com/albums/e3...709081345d.jpg
http://i42.photobucket.com/albums/e3...0709081350.jpg
http://i42.photobucket.com/albums/e3...709081350a.jpg
http://i42.photobucket.com/albums/e3...709081350b.jpg
Last edited by rwjohnson06; Jul 9, 2008 at 05:10 PM. Reason: Automerged Doublepost
I'd like to add...
Slots aside, the most important aspect of the directional orientation is the inner cooling fins. They draw air from the inside of the rotor and direct it outwards. You'll note that left and right are mirror image in respect to cooling fin orientation. When swapped, the brakes will suffer from poor cooling.
I'd like to add...
Are those the ebay ones? I plan on getting those once my business takes off in a month or two.
From: Home: Utica, MI Current Location: Mobile, Alabama
After you are done explaining that the mechanic is dislexic, I want PICSORBAN of the double assisted inverted **** stamp you plant on the service writer for the stealership.
