Rpm
stage 2 is validated 100 miles on the dyno. they should be conservative thats awesome. Stage 3 is good for 50k miles, then pistons start to crack. No warranty... s'ok.
Typical LSJ in the hands of a noob HP tuner (not area) = #4 piston done
no miles no warranty....
yea i would def listen to area he knows what hes talkin about...
has anyone seen any benefits from going all the way to 8k? has anyone even done it?
and where would you get all the stuff to doit?
if it's true .... that sux about the decreased rev limit on the GM Stage kits for the SS/SC. The 7K rev limit was a big part of the kit
. Well, at least my 07' Stage 2 has the original Stage flash with the 7k rev limiter.
the stock cams only make power to 6500ish so its not a big loss.
http://s64.photobucket.com/albums/h1...0923081722.flv
8200 is the most you can do with stock ecu
