RPMs of the supercharger?
Also whats the RPMs of say a comparable, boost wise or powerwise turbocharger.
Crank pulley is 6.0", so if you have a 3" S/C pulley, you are at 2:1
Other ratios would depend on pulley size
Turbos cant compare, at full spool, a turbo can reach near 100,000 rpms or more, depending on the turbo in question. Even Centrifical blowers spin at 50-80,000 rpms
The twinscrew blowers have differential drive, that is one rotor spins faster than the other at a 3:5 ratio. I heard it quoted somewhere as 21,000:35,000 at full speed, so I guess thats a good idea of where they land as far as RPMs are concerned. You could spin the M62 over 20,000 rpms with upgraded bearings.
Great, one more: What is RPMs of engine at peak HP & TQ, and boost?
An idea I have...don't want to say more right now hahaha...
Please do elaborate as to why you want to know this. I love hearing about new ideas and I may be able to help further given more relevent info.
From my stock dyno sheets, which are all I have on this computer, power is still going up at 6500 rpms and torque was pretty much a table from 3000-5000, so figure on 4500 or so as peak TQ.
[QUOTE=ItalianJoe1;1737997]
The twinscrew blowers have differential drive, that is one rotor spins faster than the other at a 3:5 ratio. I heard it quoted somewhere as 21,000:35,000 at full speed, so I guess thats a good idea of where they land as far as RPMs are concernedQUOTE]
ive worked with screw blowers lots with top alcohol dragsters and funny cars, (PSI blowers and whipple chargers) and i can say thats not the case. both gears in the drive are the same size, and timing of the rotors is critical. furthermore, if the rotors turned at different speeds, the blower would bind up.
[QUOTE=Sharkey;1738132]
http://www.kennebell.net/techinfo/ge...romcatalog.pdf
go there, every one they show is different, either 5:6 or 4:5 lobes. There is a male/female arrangement that is completely different from the roots setup. Like you said, different speeds would destroy an eaton, but if there are different mesh patters on the rotors they would have to be driven at different speeds. Thats the whole deal with the compression IN the blower instead of after the blower.
oops...ur right, i did diameter...but you definitely go by circumfrence and not diameter. try it for yourself...this is why you can also compare # of teeth on one gear to another, because the teeth are along the circumfrence of the gears 9assuming the teeth have the same spacing on both gears)
going by that formula
crank pulley- PI(3x3)=28.26
blower pulley (3")- PI(1.5x1.5)=7.065
28.26/7.065=4.0
and it doesnt matter in this case if i do PI(d*d), it still came out to 4
thats 4:1, meaning when the engine is at 7000rpm, the blower is spinning 28,000rpm. now iirc, the max rpm on an m62 is around 18,000rpm, meaning with a 4:1 ratio the blower is maxed out at 4500rpm.
its done by the diameter. go out to your car, jack it up and turn the crank pulley 1 full rotation and see how many turns the blower pulley turns. garuntee, itll be around a 2:1 ratio depending on what blower pulley you have.
28.26/7.065=4.0
28.26/7.065=4.0
28.26/7.065=4.0
z28addiction
09-28-2015 12:03 AM
