Running Lean up top with E85
Old Jul 12, 2011 | 09:10 AM
CobaltVenomSS's Avatar
when i tuned for E85 my AFR's were 11.5-11.8 and it pulled like a champ!
so i call my buddy last night and see if he wants to race (MS3-meth injection, intake, gutted downpipe and some other stuff, est WHP 330 or so) and i put 2 cars on him..i figured id beat him more then that.. and my buddy behind me in a SS/TC with bolt ons and tune on 93 races me and we were dead even pretty much.. i know thats not right! so i looked at my AFR's and its in the low 14's
so im thinkng i need a fuel pump
mods: TVS 2.9 80lb injectors full exhaust OTTP H/E option B exhaust and intake
Walbro Fuel Pump - Over The Top Performance
would i need this too??
OTTP Fuel Pump Rewire Kit - Over The Top Performance
Old Jul 12, 2011 | 09:18 AM
WSFrazier's Avatar
If your car is indeed an 05, you most likely will need the fuel pump. How you are still on stock fuel system is beyond me, though.
Even with a new fuel pump w/ 80# injectors, I still didn't have enough fuel with E85. Had to get the ZZP fuel kit.
You can get a GSS-342 pump cheaper than OTTP sells them for
N1ckateen's Avatar
try to find a pump thats not from ottp. goodluck man i'd hate to see somethin happen to ur car.
Old Jul 12, 2011 | 09:20 AM
Even with a new fuel pump w/ 80# injectors, I still didn't have enough fuel with E85. Had to get the ZZP fuel kit. But I am on a 2.7" ring, so meh.
yea it worked great the first tank of E but towards the end of the 2nd tank it started to take a ****
Old Jul 12, 2011 | 09:23 AM
WSFrazier's Avatar
Good news is, you can get away with a lot of mistakes running E85. I've done some **** that should of destroyed the motor.
GSS342 - Walbro Fuel Pump
this right??? just dont wanna buy the wrong thing lol
Old Jul 12, 2011 | 09:25 AM
WSFrazier's Avatar
Yeah, thats it. I drove to Summit and bought mine since I needed it that same day, and it's not a far drive.
Mine didn't come with the pigtail, though. Did mine the hard way, if that indeed comes with the pigtail, I would go with that. $75 is about the right price retail.
Old Jul 12, 2011 | 09:33 AM
startingline05's Avatar
just my 2 cents. if you are running e-85 go ahead and get a return style fuel system
Old Jul 12, 2011 | 09:38 AM
im not running E full time just when i have races set up or go to the drag strip LOL
but ill eventually get that
Old Jul 12, 2011 | 09:49 AM
WSFrazier's Avatar
Just get the ZZP BRFS kit for $199 or w/e it is and remove stock regulator. Cheap and works, just not fancy lookin.
Old Jul 12, 2011 | 09:54 AM
If I get that do I still need the fuel pump???
Old Jul 12, 2011 | 10:01 AM
Naw. But it sure does help. With the return style fuel system u will no longer be starving your #4 cylinder and ur idc is pretty much cut in half which basically allows you to run e85
Old Jul 12, 2011 | 10:16 AM
mrbelvedere's Avatar
yes you still need a fuel pump
Old Jul 12, 2011 | 10:25 AM
i have seen more number 2 and 3 cyl poppped then 4 and know one has shown definate proof number 4 pops from being leaner then the other cylnders and a return fuel system dosent cut your idc in half on e
Old Jul 12, 2011 | 10:34 AM
I'm on e85 and 80s on 26psi and my idc is no where near maxed out. So yea it does help maybe not in half but a good bit
Old Jul 12, 2011 | 10:44 AM
yea and a snail makes a difference also so its not a fair statement
Old Jul 12, 2011 | 10:45 AM
Cobalt & Ion ---> ZZ Performance
do i need any of the options??? sorry for all the q's
Old Jul 12, 2011 | 10:48 AM
yea you need the i need a new fuel pump option before i waste my money on this because it wont help with a weak pump
Old Jul 12, 2011 | 11:00 AM
im getting the fuel pump first dont worry lol
Old Jul 12, 2011 | 11:05 AM
Bika's Avatar
Fail Less.
You mentioned you are only running E on race days. Are you switching tunes when you switch fuels? Tuning for 11.8 on E is going to net a very different result when run on 93...
Old Jul 12, 2011 | 11:06 AM
yea i have a E85 tune and a 93 tune
my buddy is a trifecta dealer so we have both my tunes on his laptop
Old Jul 12, 2011 | 11:13 AM
WSFrazier's Avatar
I see ZZP offers a $100 upgrade for a "real" adjustable regulator.
I have their standard regulator, which they state you shouldn't adjust, but I did anyway. Works fine, up to ~80+ psi.
Your call on what to get get.
Old Jul 12, 2011 | 11:18 AM
Josh@ottp's Avatar
Cobaltvenomss,
Give me a call 1-810-765-4910, I can get you a walbro and a fuel pump rewire for $99, or I can get you into a real fuel system soultion (return style with pump and rewire) for $415. Everything is in stock and ships the same day.
Old Jul 12, 2011 | 11:20 AM
WSFrazier's Avatar
Or for ~$275 he can have everything he needs to accomplish the same exact thing. You don't need a fuel pump re-wire.
Not trying to tell you how to spend your money, but I can tell you what works.
Old Jul 12, 2011 | 11:26 AM
Josh@ottp's Avatar
According to ZZP's site, you can get a fuelab regulator with it now, So for $400 you can get their system with that reg and a walbro with fuel pump rewire or for $15 more you can get some braided lines and fittings that look alot nicer and don't get rid of your evap system. They seem to be the exact same thing, minus about $100 in fittings and hose.....
