S/C ported/TB Ported
Old Dec 12, 2008 | 06:02 PM
red06s/c's Avatar
Well my new found buddy Euthanasia gave me a DARN GOOD deal on some port work. he still as of today has it, so i cant tell you how it feels/sounds but it looks great! On to the pics...
Before
After
And yes it was a un-tuned meth head...
Old Dec 12, 2008 | 06:10 PM
mcphatty's Avatar
dumb dumdumdadummmbbbb...
did you research any of this, before you destroyed your blower?
Old Dec 12, 2008 | 06:11 PM
red06s/c's Avatar
Um yea, kinda like the other 15billion other people on this site has done. i didnt ask for that kinda comment so please leave.
Old Dec 12, 2008 | 06:12 PM
mcphatty's Avatar
i'm just giving criticism. sorry that everyone doesnt have positive things to say about what you did.
even eaton says "DO NOT PORT THE INLET!"
Old Dec 12, 2008 | 06:14 PM
red06s/c's Avatar
Oh do you wanna find it for me? Not saying its not true.
Old Dec 12, 2008 | 06:17 PM
mcphatty's Avatar
not particularly, but it's somewhere around here on the forums. it was a whole article with correspondence from eaton saying what things you can and cant do to your blower. porting the inlet was one of the things they said not to do, the m62 was engineered to have the best airflow possible
Old Dec 12, 2008 | 06:20 PM
red06s/c's Avatar
Well thanks for the heads up. However dudes has been doing this for years and is a well know memeber for porting, people even show 11hp gains at the fly, according to a interceptor.
Old Dec 12, 2008 | 06:23 PM
1badBlueberrySC's Avatar
And your going to believe the interceptor? The cars ECM can't even adjust to temperature changes properly!
Old Dec 12, 2008 | 06:24 PM
mcphatty's Avatar
and i hope to god that you took the blower screws out of the blower, before you ported it
Old Dec 12, 2008 | 06:27 PM
red06s/c's Avatar
Omg, this is why i am really starting to hate this site. No matter what you say, someone always thinks they are better or smarter. i didnt ask for all this...ITS MY CAR!! It my problem if its messed up. If you cant make nice comments gtfo!
1st i didnt do it, 2nd he took it apart, ported it, repacked the bearings and change the oil.
Old Dec 12, 2008 | 06:29 PM
mcphatty's Avatar
good, if any of that dust were to get in there and not cleaned out properly, say bye bye blower
and im sure there are people on this site that are smarter, and trying to offer advice.
again, sorry that not everyone is licking your sack because you ported your blower
Old Dec 12, 2008 | 06:31 PM
red06s/c's Avatar
dude you havent said one good thing in my thread. i dont want everyone to be all happy, atleast 1 nice post would be nice. please just stop commenting and go bash somebody elses thread.
Old Dec 12, 2008 | 06:32 PM
mcphatty's Avatar
i'm sure cc08 will chime in and say something cool about your blower
Old Dec 12, 2008 | 06:33 PM
red06s/c's Avatar
your such a ass. People like you make this site suck so much. gtfo!
Old Dec 12, 2008 | 06:34 PM
mcphatty's Avatar
you're the one that doesnt like it, you leave!
Old Dec 12, 2008 | 06:35 PM
SilverSurferSS/SC's Avatar
Porting the M-Series Supercharger:
It is not a good idea to remove too much material from any portion of the blower. Extreme porting of the blower will disrupt the air and will reduce efficiency greatly. A light porting of the inlet housing will help increase intake CFM of the pump. Typically, if a TB (throttle-body) upgrade is available, it helps to match the TB port size to the inlet port for a smooth intake of air with minimal disruption. Smoothing this opening up and enlarging it slightly will help introduce more air into the rotor housing which can then be "pushed" into the lower intake manifold. The inside of the housing can also be lightly ported to increase internal surface area. It is important to note, that internal porting of the rotor housing should be very minimal. Basically, remove any and all casting flashes and ensure complete symmetry while removing as little material as possible. Removing too much material will interfere with air flow and the functionality of the rotors. The output plate at the base of the M62 housing is what can be modified the most. This plate has one large triangular and two small oval passages in it. Right now, we'll focus on the large triangle. This is the passage that air is pushed through by the rotors to create a positive pressure in the lower intake manifold. This passage can be opened up slightly and smoothed out for best flow. Opening it up too much will also disrupt airflow. This is the most porting that should be performed on an Eaton M-Series blower to maintain efficiency.
From the Eaton correspondance. You Can Port the blower, just not to much, and not the air leakage ports.
I like your plugged silencer holes!
Old Dec 12, 2008 | 06:36 PM
Hockeyman's Avatar
looks great, let us know how it feels!
red06s/c's Avatar
Ok im done talking with you. Fine post what you think, but why bash my thread ? say what you got to say and stop being a ass about it.
I will be porting my blower soon as well. I hope it works out for you! Let me know how it is.
Old Dec 12, 2008 | 06:38 PM
red06s/c's Avatar
Thanks... he has to ship it back, but once i get it ima put it on and i hope the weather is nice so i can go drive it.
Old Dec 12, 2008 | 06:40 PM
Awesome. I can't see the pics at work, so enlighten me. What all did he port for you?
Old Dec 12, 2008 | 06:42 PM
red06s/c's Avatar
When it comes to modification of these superchargers, the common areas of modification are:
Porting of the inlet portion of the housing
Porting of the internal housing
Porting of the outlet plate of the housing
Porting or Plugging of the "holes" on the outlet plate
Running a smaller pulley
Heat reduction, supporting modifications
Eaton Superchargers Modification Guide - Cobalt SS Network
he...port matched the t/b to the s/c inlet and opened the outlet up a bit
Old Dec 12, 2008 | 06:43 PM
To all haters... When it comes to modification of these superchargers, the common areas of modification are:
Plugging of the "holes" on the outlet plate **DO NOT PORT THE AIR LEAKAGE HOLES!!**
fixed for you.
Old Dec 12, 2008 | 06:44 PM
red06s/c's Avatar
fixed for you.
haha thats funny, that was copyed from the eaton site.
