Safe AFR numbers?
Safe AFR numbers?
I tried posting this with the mobile app but failed.
mods, K&N typhoon intake, zzp long tube 3" catless 2.5 all the way back, front mount zzp ic, new ic pump. I am using a aem wideband gauge and interceptor gauge.
Long story short a friend of mine is tuning my car. He has nearly the same setup except he is 2.7 and I am about to go to a 2.8 but I have yet to install pulley nor injectors till after xmas. We decided to go in and tune my MAF. He left on a 2 week vacation and I am still using my car. The tune is great but still needs some fine tuning. My question is how safe is it to run with these afr numbers?
WOT
2k 14.0AFR
3k 13.5AFR
4k 13.2AFR
5k 12.8AFR
6k 12.6AFR
7K 12.4AFR
No NR unless shifting but still very minimal (1.0) and timing is normal. AIT2 is always under 100F and coolant never hits 190F
I know I should be babying the car but 2 weeks without going wot is going to drive me nuts.
WOT
2k 14.0AFR
3k 13.5AFR
4k 13.2AFR
5k 12.8AFR
6k 12.6AFR
7K 12.4AFR
Yeah i would put myself back to the normal tune and wait till those parts are in. Then go get tuned. Dont do things ass backwards and be unsafe.
You blow up who are most going to blame, their tuner, when in reality its all your fault.
its just a tune for the intake. still stock pulley and injectors.
Posted from Cobaltss.net App for Android
ima just baby it till we finish it.
The car runs so ******* great right now though. I killed a srt10 ram from a dig and a bmw on the freeway. I almost want to not believe my afr gauge but I know I probably already did some kind of damage if not weakening of the piston. like I said before I get alot of anxiety of this stuff.
What are good numbers to see at idle and cruising?
14.5 & 18ish good?
14.5 & 18ish good?
Last edited by riceburner; Dec 23, 2012 at 12:22 AM. Reason: Automerged Doublepost
I see between 13.5-15 during normal driving on my A/F ratio. Will have to check next time I go WOT.
I dont think you have anything to worry about, but dont beat the **** out of the car when its not fully tuned.
Riceburner was talking about at cruise and idle. I bet he is only seeing the 18 when he gets off the throttle and dfco kicks in. Wideband shows max lean because the fuel is cut off. If he was running 18 at full throttle we would already have seen pictures of his melted pistons on here.
Turbo Johnny
Feb 21, 2019 09:41 AM
