safe to drive until hp tune?
Old Mar 29, 2007 | 02:36 PM
orangessracer's Avatar
if i install all this stuff
zzp pulley sytem with a 2.6 inch pulley and pulley tensioner. i also own a pulley puller too. 60# siemens injectors, bosch injector harnes, cobalt-addiction cold air intake, 2 step colder spark plugs, cobalt-addiction heat exchanger, ingalls engine dampeners, polyurethane tranny mounts, megan catback exhaust system, gmp header, and xtc downpipe, eibach springs, hawk brake pads and powerslot rotors
can i drive it until i can get a hptune? what would happen to my engine?
Old Mar 29, 2007 | 02:38 PM
RaineMan's Avatar
Holy dear god no... you'll blow that sucker faster than a two dollar *****.
Old Mar 29, 2007 | 02:40 PM
braddddddd991's Avatar
yea dont do it x555
great mods though sounds good
Old Mar 29, 2007 | 02:41 PM
Red2.4SS/SC's Avatar
i wouldnt even start it
Psykostevo's Avatar
Driving it will require a tow home. Wait out on the tune *prays*
Old Mar 29, 2007 | 02:44 PM
Ljavy17's Avatar
not really, You can drive a car perfectly fine on a stock tune with 42lbers, and on a 42lbers tune while using 60lbers. I have done it before and my friends car have done it. As long as you dont go wide open throttle. Those of you who say not to do it obviously havent had experience with it. I know it sounds like itll blow up, but its not that serious unless you go wide open throttle.
Old Mar 29, 2007 | 02:45 PM
hmmm so what do i do then?
Old Mar 29, 2007 | 02:48 PM
Jimmys2007CobaltSS/C's Avatar
why do u need it hp tune? da megan catback exhaust, torque damper, headers to be tune b4ore driving? or da pulleys and other stuff need to be
Old Mar 29, 2007 | 06:02 PM
Psykostevo's Avatar
I have experience with it, and I don't advise it.
Where does it say he has a tune for the 42#'s on there. From what I read it sounds like 34# tune with 60# injectors, that will result in a healthy air to liquid ratio. Driving it would make it worse.
I had minor problems with 60's before, and that caused liquid gas to come out of my tailpipe, and then flood the motor and cause it to stop running.
Would you seriously advise someone to drive around while WAITING for a tune? I would say it's okay to drive to go GET it tuned, but not in the meantime while waiting for one.
Old Mar 29, 2007 | 06:09 PM
syP's Avatar
syP
dont see whynot... might run a little weird..
JUST DO NOT FLOOR IT or even get into boost.
Old Mar 29, 2007 | 07:08 PM
t5munoz's Avatar
do you know where i can get a 2.9in pulley
Old Mar 29, 2007 | 08:23 PM
wrxbeater11's Avatar
Yea dont drive around like this but you can drive to get the car tuned like this. just baby it. no boost and keep it low in the RPM's you deff dont wanna mess around untill your tunned.
Old Mar 30, 2007 | 12:28 AM
JMAc88's Avatar
ya, if you want to limp the car to the shop to get it tuned it shouldn't be a problem, but be prepared to be going really slow. When i put my 60's in with no tune i didn't go above 20km/h, it was a slow drive lol.
Old Mar 30, 2007 | 12:32 AM
Yea what he said, Besides trying to hit boost with un-tunned bigger injectors is just a waste of time. It flutters and shutters soo bad. Also gets pig rich, Not safe.
Old Mar 30, 2007 | 01:02 AM
rukkee's Avatar
I'd drive it to be tuned without the injectors installed , just throw them in when you get there . with a stock tune the 2.6 is just going to bypass @ 12.5 #'s ( unless u have the boost bypass mod) I wouldnt think that you will have to worry about A/F . I drove my car with stage2 to get tuned and didnt notice anything at all different .
Old Mar 31, 2007 | 04:17 AM
Psykostevo's Avatar
How is it going to bypass, when it is set to 100% boost from the factory. It won't hold much back at all.
Old Apr 3, 2007 | 09:14 PM
Ljavy17's Avatar
To whoever, gave me a negative rep in my previous post come out of the closet. Show your face! I have prove, my friend bryan, yellowcobalt06ss has been driving his car with a 60lb injector tune sing 42lbers for over a week one. and guess what newbie! no problems! You just cant go WOT, or ull blow up.
Old Apr 3, 2007 | 09:17 PM
yellowcobaltss05's Avatar
im riding around on 42lbers until my new 60's arrive and im on a 60lber tune and i didnt blow up but you should NOT boost the car
Old Apr 3, 2007 | 09:32 PM
Ljavy17's Avatar
thank you! I dont just talk outta my ass like most people here do.
So whoever said this.
"Why give the guy a chance to blow up his car?" EAT IT
Old Apr 3, 2007 | 11:56 PM
Sizzle06's Avatar
I asked this before but didn't get a clear answer,if you were to get 42# injectors and install them could gm do the reflash or is there a specific code for each stage kit they sell?
Old Apr 3, 2007 | 11:58 PM
MISSMATCHEDFACES's Avatar
DO NOT DRIVE lol...keep it simple
Old Apr 4, 2007 | 12:00 AM
Sizzle06's Avatar
Can anybody answer my question?
Old Apr 4, 2007 | 12:02 AM
gm isnt gonna do a flash for you unless its their stage 2 kit, they dont touch aftermarket ****
they only touch their own stuff
Last edited by MISSMATCHEDFACES; Apr 4, 2007 at 12:02 AM. Reason: Automerged Doublepost
Old Apr 4, 2007 | 03:49 AM
SScarTuning's Avatar
I can tell you from a tuner perspective that there is a HUGE difference between the IFR tables on 42lb vs 60lb injectors. Will it start, idle and drive....you bet. Unless the voltage offsets are WAY different or the injectors are rated at a different PSI. I wouldn't drive it very far if ou have to drive it. I wouldn't take it into boost at all. I would honestly take whatever tools I needed to swap the pulley and injectors with me and swap em in the parking lot at your tuner. I have done it many times. It is really easy and then there are no worries
brandon04
Oct 21, 2015 07:04 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
reybalt
Sep 25, 2015 08:28 PM
