Custom Exhaust
Old Mar 21, 2007 | 04:02 PM
Super_SS's Avatar
Custom Exhaust
Well i can get a shop to make me a cat-back exhaust for 100 bux...wat size should i go with,if i plan on putting a gm s2 in the summer and also would there be a hp increase if i dont change the headers and downpipe?
Old Mar 21, 2007 | 07:27 PM
BobsSilverSS's Avatar
I would go 2.5".
Old Mar 21, 2007 | 07:34 PM
NJHK's Avatar
Don't go any larger than 2.5" diameter.
Also, ask them:
"What type of piping are you using?"
"What kind of bends are you using?"
"Can I add a resonator?"
The piping type might effect the actual lifetime of the piping and how easy it will rust over time. This might be important to you, especially, for a daily driver car.
The bends are ESPECIALLY important. The type of bends you get can effect your exhaust flow tremendously. I'm not going to get too in depth on the bends part but make sure they DO NOT crush bend your exhaust system. More than likely they are going to either attampt to crush bend or give you compression bends...that price is too cheap generally for them to do mendral type bends.
If you don't know much about bends, I can explain in detail about them.
Resonator will help lower the tone of the car...lower meaning deepen the town and take away the raspiness.
Will it help performance w/o a header and b-pipe change? Yes, it can but not as much. You're no matter what, getting rid of backpressure, which is a good thing. If you're capable of increasing the exhaust size of the exhaust manifold (header) and the b-pipe (or what you call a "downpipe"), there will be more of a steady flow and of course less backpressure in the exhaust system.
If you have any further questions, feel free to ask.
Old Mar 21, 2007 | 07:41 PM
ReMz's Avatar
the way to do that with a shop is to buy your own mendrel bent piping and do an axel back with a muffler that you provide. i was going to do it at a local place for about $100, but the guy there was an old school mechanic that does more work on v8 muscle cars and asked me why i would want to ruin my car yadda yadda. after the experience with him i just said screw it, they arent getting my business and did it right with a Corsa catback.
Old Mar 21, 2007 | 08:06 PM
Belto's Avatar
Doesnt the SS has stock 2.5 diameter pipping?? just curious
Old Mar 21, 2007 | 08:08 PM
NJHK's Avatar
I thought parts of it was 2.5" and other parts slightly smaller.
Old Mar 21, 2007 | 08:36 PM
Belto's Avatar
well Im curious bc Im looking for a stock ss catback for my LT bc I had herd it was 2.5"...
Old Mar 21, 2007 | 10:06 PM
ReMz's Avatar
if im not mistaken, the piping drops to 2.25" after the axel.
it's been a while since i was looking into getting a new exhaust tho and i dont recall whether or not that is the case. just go look under your car and you can see where the piping funnels down to a smaller size.
Old Mar 21, 2007 | 11:14 PM
RBC's Avatar
RBC
Yes at the rear before it goes over the axle it reduces down to 2.25. If you would like to save some money have that part replaced as well as a muffler of your choice and it will be just as good as any other 2.5" cat back you can buy for .25 the price. The only difference is that it won't be polished like some, but who looks there anyway.
Old Mar 22, 2007 | 12:42 AM
NJHK's Avatar
Thanks RBC
Old Mar 22, 2007 | 11:35 AM
MaJ's Avatar
MaJ
SS has stock 2.5, but there are a few places with constrictions which make it closer 2" or less in some places. These are really the only places you need to replace to go full 2.5 back.
Old Mar 22, 2007 | 11:53 AM
RBC's Avatar
RBC
The "down pipe" I believe is the only other restriction.
Old Mar 22, 2007 | 04:20 PM
STG2BALT's Avatar
soo you guys are saying deff not get the 3inch pipe if u have the gym stage 2 with the 2.8 pulley
becasue i was thinkin about ethier takin the cat off my car and just haveing the flow master or just gonig with 3inch and a flowmaster
Old Mar 22, 2007 | 05:26 PM
Ryuu600's Avatar
As has been stated many times in exhaust threads, 3" is too big unless you are making 350whp or better. With that large of a pipe you are greatly reducing the low end torque while creating minimal gains in high rpm HP. This is caused by the reduction in exhaust velocity. Pump 1 gallon of water through a water hose and test the velocity then perform the same test with a sewer pipe. Reduction of backpressure is a good thing to a point, after that point you start moving your power high in the rpm range and lose the off idle torque.
Old Mar 24, 2007 | 07:10 PM
RBC's Avatar
RBC
Well I just got my quote with mandrel bends and Magnaflow muffler 12256 and it was $110. Much cheaper and just as good as after market cat-back system. I think I will get in on the pacesetter header(painted) group buy and have a great full exhaust for under $300. Not to bad!
Old Mar 24, 2007 | 10:53 PM
Asrau's Avatar
You doing a no resonator design? I tried just building out 2.5" from the factory resonator and putting a magnaflow muffler on it, it sounds like total and complete ass lol. I did a post in the 2.0L performance area describing my next trial home made set-up.
Old Mar 25, 2007 | 06:11 AM
RBC's Avatar
RBC
I am going to keep the stock cat and stock resonator. The only parts that I am going to replace is the Header, "down pipe", the 2' of 2.25 piping, and the muffler. The sound should not be to far from stock.
Old Mar 26, 2007 | 11:23 PM
RBC's Avatar
RBC
I found a guy that will sell Magnaflow muffler part #12256 for $61.58 shipped. If anyone is interested let me know and I will post the info.
Old Apr 4, 2007 | 04:13 AM
hondakiller's Avatar
where can i get a magnaflow muffler for $61? thats a good deal
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
