Scary...
Old Mar 25, 2008 | 03:58 PM
Netsyphen's Avatar
Scary...
Ok, so i'm up against this built prelude on saturday on the way to 28. We come to a light, I launch hard (3000RPM drop), and it pulls beautifully with no hop at all. Throw it into second.......it just revs, no power, just revs, throw to third, same thing. So I coast over to the shoulder, comes to a stop, shift into first and take off, 2nd and third work fine.
Next light, pull up, launch hard, pull to second..... it just revs, third, same thing.
WTF. If I don't pull first hard I can get a shift into second and lay into it, but why can't I launch hard without 2nd being reatarded, and what is the problem anyway?
Old Mar 25, 2008 | 04:01 PM
rallyracer's Avatar
It sounds like your clutch cant handle the amount power you layin down at WOT.
Old Mar 25, 2008 | 04:02 PM
TheYellowSS's Avatar
clutch def
Old Mar 25, 2008 | 04:03 PM
RedlineBrian's Avatar
fo shizzle
INDColtsFan18's Avatar
First off all your car must be fucked if it doesnt spin and wheel hop at a 3k launch in first w/o mounts. Anyways i thinmk you might have messed your tranny up or your clutch is gone.
phatnackySS's Avatar
sounds like a nice wasted clutch.
Old Mar 25, 2008 | 04:08 PM
LE5CAV's Avatar
Def Clutch, Mine Did The Same When My Pressure Plate Went Bad
Old Mar 25, 2008 | 04:24 PM
Netsyphen's Avatar
I have ETD and mounts, so the no hop is normal. Guess I need to upgrade to the Stage 3+ w/flywheel?
Old Mar 25, 2008 | 05:02 PM
07 SS/SC's Avatar
Yep like the others said, it is your clutch.
Old Mar 25, 2008 | 09:56 PM
Littlegoose's Avatar
+1 for clutch. Same thing my old 3000GT did, except change hard launch with mild start and add lots of miles on that old clutch so i got spec stage 2 and it was good to go.
Old Mar 25, 2008 | 10:49 PM
*TRIX*'s Avatar
besides for clutch did you think your syncros could be bad from misshifting and its not locking in properly (trannywise)
USMCFieldMP
Jan 25, 2007 02:56 AM
