sea level tuning
sea level tuning
does anyone know because i cant find it in the forms what a good air to fuel ratio would be with stage two, exhaust, and intake at sea level. the dealer just told me they set it at14.7 which seems a little rich is it?
rich is a lower number, 14.7 is the "perfect" ratio. Which is good to just cruise around on. Once you hit WOT though you want a richer AFR so you don't overheat and splode...... about 11.3-11.5 range.....
damn so what ur saying is the dealship actually did something right?!?!?! for the first time???
Its not the dealer who did it it was the GM engineers. Most cars today are computer controlled and the O2 sensors gives the AFR to the computer and the computer will adjust your fuel to maintaing an AFR of 14.7, once you mash the accelerator beyond and certain point all the little safeties that have been put into the computer take over so the car doesn't overheat and burn up. Though I'm sure some have been able to blow up their car anyway....
Nope the dealer had nothing to do with that GM did.
