Seafoam Question
Old May 23, 2011 | 10:55 PM
rephrase's Avatar
Seafoam Question
So i did the 1/3 gas 1/3 vacuum 1/3 oil seafoam and didn't get much smoke?
Is that good or bad? Also I changed my oil to 0w-30 Mobil 1 syn anyone use this in there LSJ?
Old May 23, 2011 | 10:56 PM
DiabeticKripple's Avatar
did you let it sit for 20 mins?
Old May 23, 2011 | 10:59 PM
exiged's Avatar
same thing with me.
I did a third of each out of a 16oz. can and didn't get ANY smoke, save for a tiny puff on a pull in first gear at 5,000 rpms.
Old May 23, 2011 | 11:01 PM
i do 1/2 vac line, 1/4 fuel (near empty) and 1/4 oil. smokes like hell. you gotta let it sit though
Old May 23, 2011 | 11:11 PM
rephrase's Avatar
I was also near empty when I did it. I let it sit for about 5-10 minutes (followed the how to) I take it you're supposed to let it sit longer?
i let it sit 20-30
Old May 23, 2011 | 11:13 PM
rephrase's Avatar
That was probably my problem then. Oh well, maybe ill try again in 5k miles lol. I did get one nice cloud on a 6k shift into 2nd. That was it though.
Old May 23, 2011 | 11:15 PM
mine just flies out the back. ill be doing it real soon, so ill get a video
Old May 23, 2011 | 11:17 PM
exiged's Avatar
hmm i thought i let it sit about 15 -20 minutes when i did it. . . .
Guess ill try it again before my next oil change and let it sit like an hour
Old May 23, 2011 | 11:18 PM
it might dry in an hour though
Old May 23, 2011 | 11:19 PM
rephrase's Avatar
On a good note, the one cloud that came out was right next to a lady gardening
/douche
felt like i was a c ummins for a couple seconds lol
Old May 24, 2011 | 02:10 AM
srt-10's Avatar
You might have needed more. I put 1 full can in my gas tank with only 20L or so of gas left, 1/4 in my oil and 3/4 in the vac line in my truck then let it sit for 15-20mins...this was the result.
YouTube - ‪SRT-10 Ram Sea Foam‬‏
Old May 24, 2011 | 02:23 AM
exiged's Avatar
wow 2 whole cans huh, maybe ill try that next time as well. . .
Old May 24, 2011 | 02:31 AM
cmatthewb101's Avatar
That **** was awesome
Old May 24, 2011 | 02:35 AM
srt-10's Avatar
I never tried it on the cobalt, so that being said, my gas tank and engine is alot bigger then a cobalts..lol. So you might need more, might not...lol. Just my .02 cents. I know the sea foam bottle will say how much to use on it though.
Old May 24, 2011 | 02:50 AM
RyanJM's Avatar
Use it on my TA all the time never more than a.little.smoke if any.
Old May 24, 2011 | 02:56 AM
Berto09ss's Avatar
hmm thats odd i never done the oil but when i did my brother's hatchback i did half on the tank and 1/4 in the vacuum line to the intake manifold and smoked like crazy too bad i didnt record it
Do u feel a difference at least!?!?
Old May 24, 2011 | 08:41 AM
rephrase's Avatar
It felt like it had a little more pep, my guess is better throttle response? but it could of freed up some ponies.
Old May 24, 2011 | 11:15 AM
JetBlackSS's Avatar
Do you let it sit with the car turned off for 20 min then drive it or let it idle for 20 min then drive it? Planning on doing this in a couple weeks when I change my oil.
Old May 24, 2011 | 01:24 PM
srt-10's Avatar
turn it off for 20 mins. Put some in the gas tank then oil, then suck it up with the vac line. You might need someone to hit the throttle so the engine doesnt stall, i had to use my throttle lever to do that. Once you finish sucking it up, shut the engine off right away and let it sit.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
