Shaving the Trans Mounts
Okay, I installed the front trans mount on my SS/SC and didn't have time to do the 2nd so i held off on it. I drove it around for a lil and noticed that it vibrated more then ever.. I figured maybe its because its uneven and i'll wait to make any changes until i get the other mount installed. I figured if the vibes were gonna be twice as bad im gonna go back to stock. So there I laid underneath of the car and found that the brackets that hold the trans mount aren't really supposed to be touching the rubber or polyurathane.. they are only supposed to be touching the metal sleeve that goes through the mount. And i've bought the cheap ones from Cobalt-addiction that have the 1/4in lip all around the mount. So in other words my mounts are touching the frame more then they should be which is causing more vibrations. Thats how people don't have much vibrations with other mounts. So to cure this problem I simply crinded down the side of the mounts untill there was enough sleeve showing for the bracket not to be touching the sides of the mount only the sleeve. I may take some pictures of my grinding the other mount but i can tell you for sure when i installed the 2nd mount that was grinded ( i still have to grind the front) the vibes weren't nearly increased as much as when i installed the front mount itself.
I'll post again when i have grinded the other mount down some to let youz know if it really works.
Sorry if what i posted is long and confusing i tryed to explain it the best i could.
I dont know whats going on with all the "bad" vibrations people are getting with certain mount installs. I agree the Cobalt Addiction bushings have a much wider outer lip that would probably touch the mount itself but I dont think thats gonna make any difference really in the vibration...but it might.
Installed front and rear TTR mounts and the car is very driveable and not any really annoying vibration at all. The engine did shake like a mother fugger and dash rattled like crazy for first 20 seconds after bushing install, then settled down and all was good. The only additional vibration is only at idle and off idle but its a good solid feeling drivetrain feel now and nothing after off idle is even the slightest crazy vibration like others I've read about.
I was suprised by all the posts I had read before installing thinking it was going to be horrible vibrations and such to the point of hating them and wanting to remove them, but it is not.
As the pics show the TTR bushing edges do not touch the mount sides at all.
^^ exactly. it's really not as bad as people make it seem. people are just too sensitive, they want the added benefit without the vibes. doesn't work that way. but they're really not that bad at all.
[/QUOTE]Yeah, see mine aren't like that... Mine are snug against the bracket on both sides... i wonder if the people that got the mounts like cobalt-addiction has are the few that have vibration issues. I have yet to shave them and see what happens. I think it'll shed some of the vibes. hopefully
Well it was pretty much the same.. if not less vibrations.
Last edited by rockkrawler628; Dec 30, 2007 at 11:05 AM. Reason: Automerged Doublepost
that being said, they should get better after a few hundred miles.
I had the poly trans mounts on mine for about 2 days. Is wasn't to bad except when just getting started from a stop. But when I turned the A/C on and it sat idling at a stop the whole interior would buzz and rattle. Way to annoying for me even though it was nice to have them for the performance.
it's a trade off. you can't have performance and a comfortable ride, if you want a comfortable ride you can only go so far.
when i had my car it took about 500 for the first noticeble break in but i would say almost all vibes went away even with the ac on at idle took about 1500+ miles or so but that was a month for me so it went pretty quick and they just continue to break in more and more
n20saturn
Sep 30, 2015 12:26 AM
