shift light... What am i doing wrong?
Old Dec 10, 2008 | 09:00 PM
ddsscobalt's Avatar
So i just installed a MSD shift light.. i connected the power ground and rpm meter to the wire on coil 4... it measures everything perfect, but i have the shift light set at 6200 to come on... it starts blinking from like 4800 on... Why is it blinking so early???? did i do something wrong or is this light defective?
Old Dec 10, 2008 | 11:23 PM
ShortStack's Avatar
... does it turn solid when you hit 6200?
Old Dec 10, 2008 | 11:25 PM
slowswap's Avatar
Do you have an MSD tach adapter? I know a lot of COP setups require the adapter.
Old Dec 11, 2008 | 01:03 AM
ddsscobalt's Avatar
i dont have an msd tach adapter.. i have the wire spliced in with the wire from the coil
shortstack-- no its really weird how it like blinks... it has no pattern at all... it starts randomly flashin from like 4800 on.. it does get solid, but it still is solid before 6200
Last edited by ddsscobalt; Dec 11, 2008 at 01:03 AM. Reason: Automerged Doublepost
Old Dec 11, 2008 | 01:27 AM
jefferyss's Avatar
you splice th wire into the coils, you hooked up a ground, you hooked up a power...is there 1 or 2 wires left over that are loop'd going backinto the shift light? if so they are your signal and you have to shorten them to make the signal closer.they usually flash when u shift and go solid when your past shift i beleave. try setting your shift point higher.
here ...this should help
https://www.cobaltss.net/forums/show...or+shift+light
Old Dec 11, 2008 | 12:23 PM
brandondrecksage's Avatar
is the tach signal set on 4cy...or whatever lsjs are supposed to be set on? is it happening in every gear? the tach is pretty slow to catch up in the first 2 gears.
Old Dec 11, 2008 | 04:56 PM
ddsscobalt's Avatar
its set at cy1... idk why but its the only way the readouts are correct on the digital reading
i followed the link above when i installed it, but i dont ahve the gmr pickup, so i spliced in with the brown and white wire like it said
Last edited by ddsscobalt; Dec 11, 2008 at 04:56 PM. Reason: Automerged Doublepost
hacadacalopolis
Oct 28, 2015 06:09 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
no_ss
Oct 18, 2015 11:58 PM
2009blackSS
Sep 30, 2015 05:57 PM
DocSvensk
Sep 27, 2015 02:24 PM
