Shimmy/shake under WOT
Old Mar 21, 2010 | 08:55 PM
BlackMagic's Avatar
I got a problem here, I have just installed the mods in my sig and under wot the whole car shimmy/shakes any ideas of what might be causing this? all help appreciated.
Old Mar 22, 2010 | 12:45 AM
YzRider452's Avatar
sub'd
Old Mar 22, 2010 | 12:47 AM
SC07's Avatar
axles, or the Cv joints more specifically. mine did the same thing.
Old Mar 22, 2010 | 12:54 AM
Sizzle06's Avatar
Is it shaking or does it seem like it's hesitating?
Old Mar 22, 2010 | 12:58 AM
YzRider452's Avatar
My car also has a slight vibration under medium/heavy acceleration. So BUMP. anybody know? Mine started right after i put my new struts/springs on. Need alignment bad.
Old Mar 22, 2010 | 01:53 AM
steveo's Avatar
did you lower the car
Old Mar 22, 2010 | 02:23 AM
rallyracer's Avatar
Could be time to replace the wheel bearings(new hubs), intermediate shaft bearing, maybe add some rack spacers while your at it (if lowered).
Im in line to do so soon...my front suspension is all out of whack right now.
Old Mar 22, 2010 | 08:27 AM
BlackMagic's Avatar
it seems to me its shaking and not hesitating. also it doesn't seem to be constant somtimes worse than others.
Old Mar 22, 2010 | 08:35 AM
rallyracer's Avatar
depending on how many miles and what not I think it may be time to replace some parts...
Old Mar 22, 2010 | 08:42 AM
PANIK's Avatar
mine does the opposite but i know my front brakes are doing it
your problem is called wheel hop
jk
i would say if it is lowered maybe spacers
front end alignment maybe?
not really sure
Old Mar 22, 2010 | 02:37 PM
YzRider452's Avatar
Yea its from right after me putting the h&rs on.
Old Mar 22, 2010 | 05:42 PM
BlackMagic's Avatar
I just drove it again an tried a few things and it seems that the wiggle is very noticable in the gas pedal...? Now i am thoroughly confused any ideas?
Old Mar 22, 2010 | 09:43 PM
osocool1's Avatar
mine was the axles and lower control arm bushings ... sucks becouse gm is the only one with ower stock axles i put after market bushing and fix mine right up
Old Mar 23, 2010 | 01:25 AM
Track Slut's Avatar
This is most likely your problem.
Old Mar 25, 2010 | 01:03 PM
StageII07's Avatar
Tire rods.. my car dose a shimmy shake type deal when i get on it then cruising it goes away my buddy checked it out and he said its my tire rods. check if theres any play in the wheels?
Old Mar 28, 2010 | 02:52 AM
wtpcobaltss's Avatar
u need the steering rack spacer. mine does the same thing on the h and r
Old Mar 28, 2010 | 04:31 AM
dom1013's Avatar
its an axle...
I just had the same problem. If it follows the RPMs more so than the road, its more than likely an axle.
Old Mar 28, 2010 | 04:22 PM
YzRider452's Avatar
I just changed my axles, no help. Next step is an alignment.
Old Mar 29, 2010 | 11:31 PM
SSLOW06's Avatar
I have the same problem seems under hard acceleration mostly . Iwill start with the cheapest part to replace ofcoarse LOL. I dont thin kits an axle bothe were changed so most likely gona be control arm bushings or some crap in the suspension and yes mine is lowered aswell i guess lowering it is puttin more stress on the busings .
Old Mar 30, 2010 | 04:39 AM
YzRider452's Avatar
Im getting an alignment done prolly this week. Ill post up if this fixes it.
Turbo Johnny
Feb 21, 2019 09:41 AM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
007Buff
Jun 11, 2017 03:04 PM
007Buff
Sep 22, 2015 09:48 AM
TylerJHowell
Sep 21, 2015 06:47 PM
