should i buy this turbo?
For Sale is a Brand New GT42 Turbo. Twin Scroll, Journal Bearing, Inlet a/r .60 Exhaust a/r 1.34. Hot Sides Can Be Swapped With Another One That Will Fit.
i can get it for 500$ been thinking about goin turbo soon and this could be the first piece of the puzzle. i have been looking at a gt3582 but this is dirt cheep.
any suggestions ?
any suggestions ?
im going to get ahold of the guy when i get back from pa this weekend. hope he diddnt sell it. this is the turbo ive been looking at do you think it would be a good choice?
GT3582R
HP Rating: 400-600
* Ball bearing turbocharger
* Oil & Water-cooled bearing system
* High Performance BCI-18 Compressor and UHP Turbine
* Perfect for high-horsepower, smaller displacement engines at elevated boost levels
* T3 turbine inlet flange and 4-bolt turbine outlet flange
* Turbine housing is cast from high-nickel "Ni-Resist" material for extreme applications
Compressor Specs:
Wheel Inducer Diameter: 61.4mm
Wheel Exducer Diameter: 82.0mm
Trim: 56
A/R: 0.70
Turbine Specs:
Wheel Diameter: 68.0mm
Trim: 84
A/R: 0.63, 0.82, 1.06
Type: Free Float
i have forged pistons w both coatings .020 over stock bore 9:7.1 comp, arp headstuds, and a mildly ported head. lots of
other stuff to but they dont really matter if i go turbo so not worth listing. im looking to get
around 500hp give or take. any suggestions on the turbo i should get are appreciated.
GT3582R
HP Rating: 400-600
Compressor Specs:
Trim: 56
A/R: 0.70
Turbine Specs:
Trim: 84
Type: Free Float
how about this one? still to big? its a precision turbo/ journal bearing. do i not want a journal bearing.. ball bearing better? man looks like i got alot to learn before i start buying parts lol.
Part Number: SC6052
Max Rated HP: 600
Inlet/Outlet Size: 3"/2" or 4"/2.5"
Bearing System: 360 Race
Garrett Compressor Wheel Trim: 60
Garrett Turbine Wheel Trim: 76
Garrett Compressor Wheel Specs:
Wheel Trim: 60
Wheel Inducer: 2.320" (60mm)
Wheel Exducer: 3.000" (76mm)
Garrett Turbine Wheel Specs:
Wheel Trim: 76
Wheel Inducer: 2.759" (70.1mm)
Wheel Exducer: 2.437" (61.9mm)
well i found a turbonetics t3/4 60-1 $850 new +$350 for the ballbearing one. so thats about the same price as the gt3582r (1280$new). hmm decisions decisions.
how much faster will the ballbearing turbo spool? is it worth the xtra $?
What you really need to do is go to Garrett Turbo's site and do all the math to figure out where you want to be with your goals and then plot them on the compressor maps.
From the preliminary info you provided though, here is my thoughts. Borg Warner S256 extended tip, if you are looking for an oil only turbo, GT3071R if you are looking for a water cooled BB turbo. The 3071R spools a few hundred rpms sooner, but the S256 shines with more power per psi up top. I suggest the .55 A/R on the BW and the .63A/R on the 3071R.
