Should I wait?
Should I wait?
Ok so im trying to decide on this so i need some input...i could order a PsiFi kit online for around $550, or i could wait till spring to order one from GM. They both put out the same power but i dunno which is the better buy. Thanks
the GM article said that the stage 2 would put out around 45 hp, the PsiFi would do that without injectors or n ECU flash. That just confused me. Im going to wait till after SEMA to make my decision.
id wait , why lose warrenty before you can have factory fun
i just hope the stage 1,2,3 dont come out like the 2.4 twin cam s/c did , took way to long
the s/c kit for the 2.2 eco's , is slowly headed that way
but hopefully there will be a decent answer at sema , for both the stage's and the 2.2 eco s/c
ill try and find out monday while im setting up out booth
I'd like to be wrong, but I wouldn't expect a single Staged upgrade to happen for at least 6 months after SEMA. Then if you have a Saturn it probably wont be included and depending on the success of the Stage 1, Stage 2 and 3 may never come out.
If GM bases the price on performance then it will be too expensive, but if they base the price on labor time; Hopefully it will be inexpensive enough to be worth it.
