sky trannie?
Old Jul 5, 2006 | 11:29 PM
Shermen's Avatar
sky trannie?
does any one know if the saturn sky trannie will bolt up to the 2.0L? just a thought for a rear wheel drive conversion.
Old Jul 6, 2006 | 01:14 AM
Nocturn's Avatar
I believe so since the Sky Redline uses a 2.0Turbo
Old Jul 6, 2006 | 08:09 AM
BooSSted's Avatar
If your going to to through the trouble of doing a RWD conversion, throw in a small block
Old Jul 6, 2006 | 08:57 AM
NJHK's Avatar
How come you wanted to know?
Old Jul 6, 2006 | 01:28 PM
97cavie24ls's Avatar
all eco tec 4cyl use the same bolt pattern for the belhousing
also the solstice trans is from the colorado/canyon trucks , so you can use the trans from them , easier to get
Old Jul 6, 2006 | 01:29 PM
Shermen's Avatar
was just wondering and because i was talking to a guy that converted his cavie to RWD and i thought it would be cool to look into.
Shermen's Avatar
thanks that is what i wanted to know.
Old Jul 6, 2006 | 01:41 PM
actually that is what i will be doing with my 97Z24 that i have , it will be a rear drive turbo 2.4eco
i thing i should mention , the 2.2 and 2.4 use a 6bolt flywheel
the 2.0 uses a 8 bolt flywheel
so youll need to keep that in mind when doing the clutch
Old Jul 6, 2006 | 03:18 PM
Shermen's Avatar
do you know if it is possible to run the SKY's clutch and flywheel ( but i can get a flywheel redrilled and balanced.)
Old Jul 7, 2006 | 01:29 AM
i think you should be able to use the 2.0's clutch , if not the redline and gxp should be out soon
OrangeCoba
Oct 1, 2015 10:00 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
zdohare
Sep 23, 2015 11:31 AM
