The slow Govenor is attempting to go faster
#96
COMP Cams: Xtreme Energy™, XE264HR-13 <BR> Strong Power, Street/Strip, High RPM
go read the spec card
fyi zzp dose the duration incorrect industry standard is at .050 in of lift zzp does it at 1mm which is .039 in of lift which makes the cam look bigger then it is
ZZP S3 is 216/224 @ 1mm and 10.78mm/11.10mm lift, 113 LSA
.424 /.437 lift in inches
here is the correct lift a duration for the zzp stg2
http://www.compcams.com/Company/CC/c...csid=1080&sb=2
