SMS Intake manifod?
SMS Intake manifod?
Anyone know if this intake manifold would fit on a balt?
http://www.saturnmotorsports.com/cat...roducts_id=574
just curious cuz it looks like it would work really well for a turbo setup
How would you get that to work in conjunction with the S/C................. I mean I may be missing something but our intake manifold runs underneath the S/C the Thread OP has an SS/SC hence my answer!
Three things to look out for here:
1. The injectors provisions are in the manifold on this one, and they are not in the manifold on our cars so they would have to be welded shut.
2. While it may mount up to cylinder head, it may not bolt up to the throttle body.
3. You will have to drill and tap and or weld spots for the map sensor, the sensor on top of the supercharger, and the brake booster hose if it is not on there.
Those are just some things to look into. If Golden Eagle makes it, I bet they can have them made without the injector ports and the correct TB holes if needed though.
OrangeCoba
Sep 25, 2015 06:06 PM
