So, I've decided on a 2.7"
Old May 15, 2008 | 12:05 AM
RedEcotecSS's Avatar
I believe I'm going to begin with getting a set of 60# injectors. Would the 2.7 be safe for daily driving? Current cooling mods I have is a Cobalt Addiction H/E. What else is recommended? Meth? Dual pass? Thanks.
Old May 15, 2008 | 02:32 PM
UmeNNis's Avatar
Of course the more cooling mods the better as always but with the 2.7 you will be fine as long as you don't do multiple back-to-back track runs at wot. It is the 2.6 and lower that you actually NEED to start thinking about meth and more extreme cooling solutions.
Old May 15, 2008 | 02:46 PM
Joeyavhu's Avatar
Get some water wetter from Autozone or one of those stores. People may not give it much respect, but I did 11 runs in less than an hour and a half and my IAT's didnt get about 150 the whole night. That is my only cooling mod right now too. Just run it straight water and water wetter, if you live where it might freeze, it is probably good to put in some coolant.
Old May 15, 2008 | 04:26 PM
Area47's Avatar
Rent me! per hour
comparing a 2.9 to a 2.7 in terms of heat ranks right up there with comparing an apple to a wet fart.
Old May 15, 2008 | 04:28 PM
AlphaJaguar5's Avatar
Or an irate panda to flaccid golden retriever.
Old May 15, 2008 | 04:31 PM
powerz's Avatar
Old May 15, 2008 | 04:32 PM
Area47's Avatar
Rent me! per hour
Originally Posted by AlphaJaguar5
Or an irrate panda to flaccid golden retriever.
never seen an angry panda, and why are you lookin at a dogs junk?
Old May 15, 2008 | 04:34 PM
Joeyavhu's Avatar
Fine fine, I was just trying to help. Lol It certainly doesnt hurt though.
Old May 15, 2008 | 04:35 PM
SJSchafer's Avatar
Dual pass w/option b, meth and another step colder plugs.
Old May 15, 2008 | 04:38 PM
BriantheLion26's Avatar
OK i just about pissed myself on that comment.
Old May 15, 2008 | 04:40 PM
SJSchafer's Avatar
He has a way of doing that. There's a little button under his left armpit. If you push that in and disconnect the vacuum line to his intake, he'll stop. The bad news is that he'll start to stutter.
Old May 15, 2008 | 04:41 PM
Old May 15, 2008 | 04:45 PM
SJSchafer's Avatar
There's actually a way to tune out the stutter, but HPT doesn't support that parameter on his PCM.
I heard tell of a beta Area47.1.2 that may do just this.
I'm sorry. end jack...
Old May 15, 2008 | 04:57 PM
ralliartist's Avatar
I wouldn't run below stag 2 pulley without all the cooling mods. But that's me personally.
Old May 15, 2008 | 05:07 PM
Area47's Avatar
Rent me! per hour
um. d00d. stop stalking me.
the stutter is refered to as a fart
Old May 15, 2008 | 05:15 PM
SJSchafer's Avatar
Not stalking, just bored. Stop posting in the threads I want to post in.
So that explains the smell. Does the Area47.1.2 beta have a PID to log that?
Old May 15, 2008 | 05:18 PM
ok. on topic now.
Area, what would you suggest I get to run the 2.7 safely? Would it be alright for a DD?
Old May 15, 2008 | 05:28 PM
Area47's Avatar
Rent me! per hour
stay above a 2.8 with 60's and be happy
the key strokes in the PID table to set up the smell log is oh you ate one two
Old May 15, 2008 | 05:34 PM
SJSchafer's Avatar
I think with the proper cooling mods, he'll be fine with a 2.7.
0U812? I thought it was "C : <enter> : ###". Must be a different tune.
but i want more power than just a 2.8.. i have a 2.9 w 42's right now. what other routes should i go?
Old May 15, 2008 | 05:35 PM
OneSlowGto's Avatar
I personally liked the 2.7. Just make sure you have a good tune and you will be fine.
SJSchafer what did you end up putting down on the dyno?
Last edited by OneSlowGto; May 15, 2008 at 05:35 PM. Reason: Automerged Doublepost
Old May 15, 2008 | 05:42 PM
SJSchafer's Avatar
You can get a ton of power off of a 2.8, 60's, cooling mods and a tune. Meth will really let you open it up. My meth kit got me up to 21* of timing with a bad meth mix and the cars still pulls like crazy, and I run a 2.85. I'll get more with a better mix. A smaller pulley is great, because of the extra boost, but a good PE curve, timing and a cool intake charge FTW. Do NOT go smaller than your current sized pulley without injectors.
I never got a chance to re dyno after that one meet.
Old May 15, 2008 | 05:43 PM
OneSlowGto's Avatar
Shitty. We need to get you back on the dyno
Old May 15, 2008 | 05:44 PM
I'm so confused as what to do. lol
Old May 15, 2008 | 05:47 PM
SJSchafer's Avatar
Nah, you don't want to do that now.
Dude, you are on the right track with your current mods. You need cooling next. You have the HE. Put in a dual pass and a stage 1 meth kit and see how you like it. You should do those before you go any smaller on the pulley anyway.
