Solid Engine Mounts
Old Mar 5, 2007 | 10:06 AM
PolishPauL's Avatar
Solid Engine Mounts
http://bwoodyperformance.com/product...4fc86865285e00
I jus wanna know how bad the vibes are. I heard one person say that they calm down after 500 miles and another say that they dont ever calm down. I really want them but dont want to deal wit a ton of vibes because this car is gonna be my daily driver. I wanna get solid tranny mounts too, but that may be too much...
Old Mar 5, 2007 | 10:11 AM
SKDR112888's Avatar
wil lthe redline motor mounts for the ss/sc?, I think they will but I want a 100% answer,
Old Mar 5, 2007 | 10:31 AM
SS33's Avatar
I believe you will get alot more vibes from a solid motor mount, than from the trans mounts due to the mounting points.
Doing the trans mounts only stiffens the coupling to the frame, where as the motor mount goes directly to the body of the vehicle, and therefore directly into the cabin. I have done the trans mounts, CAB's, and the Ingals dampener on mine. And the vibes did decrease after a break in (~500-700 miles), but I never thought they were that bad anyways
Having been in cars with the solid motor mounts I can tell a difference,,, but I may eventually swap out my dampener for a solid mount, as the dampener doesn't do much for me at this point. Ultimately if you want the best traction possible in our cars you will have to deal with some vibes.
Hope that helps
Old Mar 5, 2007 | 11:20 AM
Shortbus's Avatar
Your going to get vibes period, its a either you deal with it, or go without.
Old Mar 5, 2007 | 11:25 AM
bc3tech's Avatar
yeah they fit. and if they don't bwoody's awesome and will take 'em back no questions asked
Old Mar 5, 2007 | 11:35 AM
RaineMan's Avatar
I've ridden in a RL with solid motor mounts... and my SS/SC has the Stiffy... there isn't that much of a difference... the only time it even vibes at all is if the AC is on.
Old Mar 5, 2007 | 01:45 PM
yzfr6avid's Avatar
Well it really depends on what type of insert they are using. I know that the Avid mount that Tag is selling are made from polyurethane. Also the Cobalts are not making too much power right now so the driver and passenger side mounts aren't neccessary. The engine torque is 70% controlled by the rear and front motor mount. Hope this helps.
Old Mar 5, 2007 | 04:41 PM
SilverSS/SC's Avatar
I jus wanna know how bad the vibes are. I heard one person say that they calm down after 500 miles and another say that they dont ever calm down....
They wouldnt ever calm down . The bushings on the trans mounts might over time , but the engine mount is all metal ...no bushing . The vibes you get from it will always be there . I ran Solid mounts and a poly trans mount in my 95 Trans Am with a very lopey 248/252 duration cam . It wasnt any worse than all poly IMO . No clue how that comparison would translate to a FWD .
Old Mar 5, 2007 | 11:12 PM
PolishPauL's Avatar
Are there any solid control arm bushings because dont those not add any vibes?
Old Mar 7, 2007 | 10:54 PM
PolishPauL's Avatar
Old Mar 7, 2007 | 11:02 PM
n8dogg's Avatar
what would u want solid control arm bushings for? good way to have a shitty ride without gaining anything
Old Mar 7, 2007 | 11:14 PM
PolishPauL's Avatar
I heard they dont add vibes. I dont really kno wat they are
Old Mar 8, 2007 | 12:24 AM
n8dogg's Avatar
people are forgetting, you can replace mounts all day, but think about what your doing. You replace something thats weak, well it creates a new weakest link. You put motor mounts, and trans mounts, and control arm bushings, well now you have hardly any movement in your powerflow, your going to start putting excessive wear and tear on your drivetrain components. The splines in your trans and axels are going to start to wear, and have the potential to break. Your clutch springs arent going to beable to absorb all of the impact anymore, and dont forget about the clutch chatter.
Also, if your putting CAB's in, what about the strut top? the strut can actually pivot, and if your control arm bushings arent going to absorb the impact, its going to be directed into your strut top, and replacing those bearings/strut tops arent exactly cheap.
Unless this is solely a race car, replacing all the bushings isnt the greatest ideas, invest in a clutch, stronger axels, smaller wheels and better tires if you want to take it to the track once in awhile.
Old Mar 8, 2007 | 01:21 AM
Blown 4-banger's Avatar
I have the ZZP billet motor mount, and ZZP poly trans mounts. Lets just say, I can't wait to give a girl a ride in my car
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
