Someone with Intense 3 help me out
I dyno'd 237.4 this weekend and needless to say i'm a little disappointed. What are your plugs gapped at. I ran really rich too so I am going to switch to C 0 and do it again next saturday morning. Any advice guys??
Originally Posted by BLKSS
I dynoed 222 with stage 2 from GM consider yourself lucky. Most people dynoying 260 are either full of it or using dynojets.
Sorry, I should have clarified that I was talking to J-Rod. I have no experience with the GM kits, just the miniscule amount I know about the Intense kits.
Yes, and no I didnt they were booked.
I haven't seen anyone dyno 260+ that' "full of it".
To the poster, how about listing ALL of your mods, and settings. Make sure the plugs are gapped at .045, and it sounds like you need to lean it out a bit. I've seen people's traps go up 2+ mph by leaning it out over the standard INTENSE settings. The INTENSE settings are good, just a bit rich to keep it safe. If you have a scanner and a wideband, dialing it in will be easy, and will net you good gains. Most of Fast06SS's progress is because of him learning his car, and making sure it's dialed in. Look at the bright side, blkss waited a long time to have his "precious" warranty, and you're making more than him.
Even without the sweet 7k redline that puts extra stress on the valve springs.
Very True!!
As far as the 260+ comments go.... Rob's posted a few dyno sheets on here that prove his car is dialed in making over 260. As far as full of it, track times show the power is there and that's more important then dyno numbers.
It's all about learning how the car reacts and settings. I normally run a C0 now when the weather is 70 and up.
What many people need to realize is that different dyno's read differently. That is why it is a good idea to get a baseline on a dyno, do mods, and then go back to the same dyno to get an accurate idea of your improvements. For example, I went to Evolution Motorsports on a Mustang dyno and got 231whp with only an Injen CAI. After more mods, I plan on going back to the same dyno to get results.
Also, from what I've heard, many people who buy the Intense kit just want to bolt it on and go and get 270whp!! That is not going to happen. The whole point is to be able to tune your car with the new mods. That is what makes the setup work so well. Play around with it.
i really dont think tuning is that necessary...everytime rob does something he makes the most power on the c1 setting. I know for me that is also the seeting that works best for driveability.
Dan
Dan
Originally Posted by J_Rod
Could the gaps being off make the car run rich???
On C0 settings I was 845-860's Some might consider that a little too lean so I would suggest C1 to start and see where the A/F is with a .045 gap first.
i got the intense kit and my settings are c 2 and my car runs like a rocket. raced a bonestock ss/sc last week pulled instantley got him buy 6 or 7 cars coming from the driver of the cobalt.i got a a/f gage and at wot yea it gets rich.
whats the benefit of doing a .45 gap over thet stock .35? Anyone think this would be a benefit to those with the GM stage 2 kit, or anyone can give the underlining reasoning why this is beneficial to an intense kit and not the GM?
Originally Posted by ENUFPWR
Yes.... I think so from some runs I made at the track(Lapeer last weekend). I gapped my pulgs at .035 and made a pass. I then came back and regapped them at .045. Difference was I gained 2mph in trap with simular 60fts. O2 reading on the aeroforce gauge were 880-990 with IAT2 at 130-150 during the passes with .035 gap. When gapped at .045 I was 860-870 with IAT 135-150 but gained 2 mph. On C1 settings....
Thanks again
