something wrong?
something wrong?
well b4 i got my downpipe on i had a clogged cat....so b4 i knew it was clogged i raced a 85' vette..we were dead even from a 40 roll and when i shifted into 4th he put a whole car on me...(cat was clogged in race btw) well now that i got my downpipe on i wanted another run and i got a different outcome..same race tho 40 roll....we go and i put 2 cars on him instantly and he stays there when i shift into 3rd but when i shift into 4th he pulls on me again
but in that race right b4 i shifted into 4th...at 6k RPMS its like it missed for a split second..then it went on like normal....its done this b4...is it the injectors or spark plugs what?
help!!
help!!
Last edited by CobaltVenomSS; Jul 21, 2008 at 03:49 PM. Reason: Automerged Doublepost
help!!
help!!
1. At 6k you shouldn't be maxing out the injectors with your smaller pulley.
2. Could be belt slip but doubt it if you're running stage 2 belt.
3. Best guess is a misfire but not enough to cause limp mode.
4. Could also be some problem with your clutch slipping or oil leak onto your clutch plate (heard this before).
Iridium plugs run great in my car...they're gapped at .35 out of the box. Technically should gap from anywhere between .35 to .40 on stage 2, you can run factory plugs (ngk-r's) but you should go one step colder. I think the most available plug is autolite 3922 but no info on how they run.
Last edited by theneelster; Jul 21, 2008 at 07:44 PM. Reason: Automerged Doublepost
did a 2nd and 3rd gear pull tonight..and it pulled harder than B4
but i cant wait for the temp to go down outside it was 100 degress
car like 40 degrees better lol
