spark plug cover bolts
Old Jul 21, 2007 | 12:16 AM
Connor05's Avatar
Does anyone know where i can get the part number for the bolts on the LSJ, or where i can get them offline
Old Jul 21, 2007 | 10:36 AM
OZERMAN's Avatar
12789897
Old Jul 21, 2007 | 11:08 AM
Connor05's Avatar
thanks alot
Old Jan 3, 2012 | 01:43 AM
rectorc08's Avatar
Thank you as well. Just had to extract 3 of mine since they were stripped.
Old Jan 3, 2012 | 03:18 PM
Leafydialupking's Avatar
6x1.00 x35mm at the hardware store?
Old Jan 3, 2012 | 04:54 PM
sLAsh's Avatar
I am thinking I am going to have to pick up a few as well.
I tried a couple of them and gave up before they stripped. Put some PB blaster on them and will try again on the weekend.
What's the easiest way to get these out if they strip? Dremel a slot in them and turn em out with a flathead or drill the heads off and try to undo them with some vice grips?
Old Jan 3, 2012 | 05:37 PM
How are they getting stripped? its steel into aluminum and with a very low torque spec.
Old Jan 3, 2012 | 06:16 PM
keiserX13's Avatar
im missing one of mine
Old Jan 3, 2012 | 11:29 PM
sLAsh's Avatar
Not sure cause I haven't stripped it yet
Just felt like the torx bit was gonna slip so I stopped before it happened and put some PB blaster on them. When I saw this post I figured it was going to be a pain in the ass and posted to see what people were doing to get them out.
Old Jul 1, 2012 | 01:41 PM
CrashMurphy's Avatar
Pro Grabit® 4 Piece Kit
Tried a set of these and it was super easy. Drilled in with the largest bit, flipped it around and took it out with a crescent wrench.
DarrenGC
Dec 24, 2021 01:55 PM
dennis69
Oct 20, 2015 04:49 PM
717ssbalt
Oct 2, 2015 04:01 PM
SSLOW06
Oct 1, 2015 07:21 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
