Spark plug gap with 2.9" pulley
Old Jul 30, 2007 | 04:21 PM
L.P.'s Avatar
Today I just picked up some NGk BKR7E's and I was curious as to what gap I should use with these for my 2.9" pulley setup, thanks.
Old Jul 30, 2007 | 04:24 PM
CTCOBALTSSS's Avatar
.35 should be perfect!
Old Jul 30, 2007 | 04:29 PM
L.P.'s Avatar
Are the plugs I got good enough for the 2.9" pulley they are only 1 step colder....for some reason I was going off of cobalt addictions website and it said .40 but I figured people with expierence would know better, thank you though + rep
Old Jul 30, 2007 | 04:32 PM
Matty's Avatar
Anywhere in between .035-.040" will be ok. Yes the plugs are good.
Old Jul 30, 2007 | 04:33 PM
blackngold20's Avatar
yeah I got mine at .040"
Old Jul 30, 2007 | 04:35 PM
L.P.'s Avatar
I will go with .40 most likely..question will the car run alot smoother with these plugs over the stock ones?
Old Jul 30, 2007 | 04:36 PM
Doc's Avatar
Doc
.040
Old Jul 30, 2007 | 04:38 PM
Coblt ss super's Avatar
how bout for a 2.8?
Old Jul 30, 2007 | 04:40 PM
Matty's Avatar
Originally Posted by Coblt ss super
how bout for a 2.8?
Same gap.
Old Jul 30, 2007 | 04:41 PM
Originally Posted by Matty
Same gap.
.40?
Old Jul 30, 2007 | 04:47 PM
Matty's Avatar
.40?
When I had the 2.8 and the NGK's that's where my gap was and it was fine.
Always use the biggest gap possible and work downwards. If you find .040 not working then try say .037"...and so on till you find what works best for your setup.
L.P.'s Avatar
will these plugs make the car run smoother?
Old Jul 30, 2007 | 04:48 PM
haha idk how to tell wat works best
Old Jul 30, 2007 | 04:49 PM
Matty's Avatar
If the plugs you have in there now are bad, then yes.
Old Jul 30, 2007 | 04:53 PM
u think the new plugs will also make my idle stay at a certain spot? becuase all it does is jump everywhere!!!
Old Jul 30, 2007 | 10:18 PM
L.P.'s Avatar
Thanks for all the help guys, going to be putting the plugs in tomorrow....needed to get them in before I leave to the track tomorrow.
BTW out of the box what are these spark plugs pre gapped?
Old Jul 31, 2007 | 09:52 AM
L.P.'s Avatar
Got the plugs in it runs much smoother overall throughout the whole power band, I am very impressed. Went with a .040 gap as well.
DarrenGC
Dec 24, 2021 01:55 PM
Oct 20, 2015 09:56 PM
717ssbalt
Oct 2, 2015 04:01 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
