spark plug gap?
Old Sep 19, 2007 | 06:18 PM
silentd's Avatar
spark plug gap?
what should i set mine to? i have the step 2 colder ngks from cobalt-addiction.com
on their site for the stock stage 2 pulley they say .045 so i set mine to .043... is that good? it seems to run good
mods in sig
also i went with the step 2 because im going to be running nitrious
Old Sep 19, 2007 | 06:24 PM
an0malous's Avatar
0.43 is a bit wide.
i submitted a howto on this because its such an oft asked question. but it hasnt been approved yet.
Try at least 3-5 different gaps.
every car is different, in different conditions, with different mods.
I have no idea why they are suggesting gaps that wide. stock is 0.40, and generally you will get a little smaller as you make more power.
Try 0.40, 0.37, 0.35
see how the car likes each one, and remember, a rule of thumb is....ONLY go smaller if you have to.
If your having any sputtering, idle issues, misfires at wot etc etc, go a little smaller.
Old Sep 19, 2007 | 06:25 PM
silentd's Avatar
gotcha ill try that 2mm when i get a chance.
Old Sep 19, 2007 | 07:24 PM
07cobaltss's Avatar
my car digs .030
Old Sep 19, 2007 | 07:50 PM
glockglade's Avatar
if i am having idling issues do with a .35 mm gap do you think i should open it up some or close it some more. i also have 60 pounders which might be my idle problem as well, but just as of recently the car is starting to stall at idle. it never used to and i have been running the .35 gap for quite some time.
Old Sep 19, 2007 | 08:03 PM
OneAMCoffee's Avatar
Not to hijack the thread, what about with the stage 2 and a 2.9" pulley, does anyone have any general tips? Thanks!
Regards,
Ryan
Old Sep 19, 2007 | 08:05 PM
glockglade's Avatar
Regards,
Ryan
try .37 or .40
Old Sep 20, 2007 | 11:38 AM
an0malous's Avatar
my first assumption would be the 60s causing the idle issue.
but its easy to check a few gaps to see if it helps.
to the guy asking about S2 and 2.9, read my first comment.
it basically applys to any car.
start with the stock gap. try 3 or 4 different gap sizes smaller than that, and take close notice of how your car reacts to each setting.
the idle....any surging....any misfiring or sputtering...
any blowout or sputtering at WOT etc etc
dont assume theres a quick fix gap for you.
every car is different, and its in your best interest to spend a little time finding the gap that your car likes.
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
