Spark plug's!!
Old May 20, 2008 | 09:54 AM
Cyclone's Avatar
Spark plug's!!
Yeah i know there are a few threads like his but what the hell!! I am gm stage 2 and i just ordered nate's 2.8 pulley i want to run a step colder spark plugs what are some parts numbers and brands that i can go to my local parts store and pick them up ??
Old May 20, 2008 | 10:03 AM
rnjmur's Avatar
Most people stick with the NGK plugs. BKR7E for copper plugs, BKR7EIX for Iridiums. If you plan on running the car hard go with the copper plugs. If you are going to be easy on the car go with the Iridiums.
Old May 20, 2008 | 12:09 PM
Cyclone's Avatar
Thanks!!
Old May 22, 2008 | 11:59 PM
cobalt ss/sc's Avatar
autolite 3922
Old May 23, 2008 | 12:03 AM
flash13brandon's Avatar
what is the main difference between iridiums and copper?
Old May 23, 2008 | 02:21 AM
rnjmur's Avatar
The material that the electrodes are made of.
The real question would be what is the difference between copper, iridium and platinum. Different metals have different properties when it comes to electrical and thermal conductivity. The higher the electrical conductivity the better spark you will get and the higher the thermal conductivity the quicker the electrode dissapates the heat generated by spark and combustion in the combustion chamber. Another point to consider is how quickly the electrode material erodes from spark burning off little bits of the electrode. Typically the harder the metal, the longer it lasts.
Copper is the softest of the metals, however it has the best electrical and thermal conductivity of all the spark plugs. Copper is 2.5 times more thermaly conductive then Iridium and about 3 times as electrically conductive. Due to the soft material however, copper plugs wear very quickly.
Iridium is the hardest of the metals, and because of this it is able to be made into a very fine electrode helping the electrode from holding heat. Iridium is twice as thermally conductive and twice as electrically conductive then Platinum. Due to the very fine electrode Iridium is actually able to cool much better, probably about 3 or 4 times better then platinum plugs.
Platinum is harder then copper but softer then iridium. Copper is almost 6 times as thermally conductive and 6 times as electrically conductive as platinum. However since platinum is a much harder metal the electrode can be made much smaller allowing it to help stay cool and the material lasts much longer then copper plugs.
For a typical N/A car platinum plugs work fine. The car doesn't need an extremely powerful spark and doesn't need to worry about staying extremely cool plus typical drivers don't want to have to hassle with changing plugs and platinum allows them to go (under ideal circumstances, of course) up to 100K miles before a spark plug change. Forced induction cars (especially newer FI cars) typically use iridium plugs because of the better spark and ability to cool better then platinum while still allowing extending periods before having to change the plugs. However, for a race car or for maximum performance out of your car, copper is always the best way to go. Copper cools much better and has a much more powerful spark, helping to prevent spark blowout but the plugs have to be changed 4 to 5 times more often then platinum or iridium plugs.
Old May 23, 2008 | 04:42 AM
Maxim_X's Avatar
Great post^^^^^
Old May 23, 2008 | 11:29 AM
so what plugs would you recommend with Stage 2?
Old May 23, 2008 | 05:54 PM
mrniceguy8211's Avatar
Denso ik22
Old May 25, 2008 | 12:52 AM
rnjmur's Avatar
According to GM the stock platinum plugs are fine for stage 2 however I would be concerned with possibly getting spark blow out because of the increased compression. Personally, I put Iridiums in my car when I had stage 2 installed. If you are going to be running the car hard all the time you might consider copper. I don't run my car hard and don't get on it alot so I just stick with the iridiums (plus I have a few other mods, K&N - header - exhaust and stage 3 pulley so going one step colder wasn't a bad idea). On a stage 2 only car with no other mods you are probably fine with the stock heat range iridiums.
Old May 25, 2008 | 01:03 AM
but would 1 range coler iridiums or copper produce any benefits?
Old May 25, 2008 | 12:33 PM
ok...so would one range colder with a stage 2 produce any benefits?
Old May 25, 2008 | 12:53 PM
I noticed a difference with the ik22 ( one range colder iridium ) plugs in the top end, and in gas mileage. I am Stage 3 with a 2.8 inch pulley. The denso ik20 plugs were very good for me when I was just stage 2 with a 2.8 in pulley. The ik20's are stock heat rang iridium
Old May 25, 2008 | 12:54 PM
M-Dub's Avatar
Have fun with that 2.8 on a stage 2 tune!
Old May 25, 2008 | 01:00 PM
when you had stock heat range iridiums...did you see a difference?
Old May 25, 2008 | 01:06 PM
Acceleration and throttle response was better, and I got better MPG's. I ran the stock heat range for like 4 months on the stage 2 tune, when I took them out they still looked like new.
Old May 25, 2008 | 01:12 PM
do you think i would have the same results with one stage colder or better results?
Old May 25, 2008 | 01:14 PM
forced_induction's Avatar
very nice information
Old May 25, 2008 | 01:35 PM
It depends, what are your mod?
Old May 25, 2008 | 01:51 PM
Stage 2 with AEM Filter
Old May 25, 2008 | 01:55 PM
It might help, here are pics of the denso Ik20's stcok heat rang, when I went stage 3 and put in the Ik22's one range colder
Old May 25, 2008 | 02:20 PM
so it looks like you didnt have any problem with those?
Old May 25, 2008 | 02:30 PM
None at all, I was very pleased with them. I just switched to the colder ones when I installed the stage 3 computer and cobra h/e. I also get about 1 to 1 1/2 more miles per gallon with the iridium's ver. the stock double platinum's. I tried the NGK BKR7e copper plugs also, but the throttle response was not as good as the iridium plugs. Another thing that helped my throttle response was cleaning out my throttle body with some tb cleaner and a toothbrush. My rpm's don't drop as quickly between gears now either.
Old May 25, 2008 | 02:50 PM
depending on where you live, would colder be needed more like down here in florida?
Old May 25, 2008 | 03:00 PM
hungryhip-ccp's Avatar
those were from switching to the stage three ecm... i noticed the same things...
