Spark plug's!!
Old May 25, 2008 | 03:05 PM
flash13brandon's Avatar
so your saying the plugs will not help mpg?
Old May 25, 2008 | 04:20 PM
mrniceguy8211's Avatar
I noticed a difference when I was still stage 2
Old May 25, 2008 | 04:37 PM
thats what im hoping for...so if its hotter where i live...do you think i should go one stage colder or no?
Old May 25, 2008 | 05:13 PM
hungryhip-ccp's Avatar
no im not saying that... if a car isnt running properly to begin with and then you change plugs then yes it may help your gas mi. but if you are just gonna change heat ranges well then think about it at wot your getting like 4-5 mpg so dont measure there, which is where/what plugs will effect... so at light throttle (cruise) a different heat range wont effect mpg... jmo
Old May 25, 2008 | 08:49 PM
ok...so buying just iridium plugs over the stock ones will not help to much...only at WOT?
Old May 25, 2008 | 08:51 PM
berto's Avatar
Buy Pulstar Plugs Like Me
Old May 25, 2008 | 11:39 PM
rnjmur's Avatar
Spark plugs are a funny thing. By going to colder plugs you are changing the tempurature in the combustion chamber. There isn't any easy way to tell how the temps are in the combustion chamber so you kind of have to "guess" as to when you should change the plugs to colder ones. The rule of thumb is approximately every 75 hp you go one step colder.
As far as pulstar plugs go, the theory behind them is good but there isn't much research or testing done on them in F/I cars. After a few people use them for a while then I may consider trying them out.
Old May 25, 2008 | 11:45 PM
Mr McCabe's Avatar
While we're all on the topic of spark plugs... what would one gap new spark plugs to?
Old May 26, 2008 | 12:45 AM
what are your mods?
Old May 26, 2008 | 05:43 AM
ya i was wodering the same thing...Stage 2 and Aem flter?
Old May 26, 2008 | 06:38 AM
  #36
every engine is different but ide say start at 34 and work your way down dont go past 28, that should be your range but your only makin like 14-15 lbs boost so you shouldent need to go too small... if it were me ide gap at 32 and call it a day (unless there is drivability issues)
ohh and i was speaking of copper plugs NGK 7's... i think iridium's needs to be smaller they start at 28...
do a search there was tons of these threads just months ago...............noobs
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
