spark plugs
Old May 9, 2009 | 10:29 AM
doug41176's Avatar
spark plugs
I have a 05 ss supercharged whats the best plugs to run in this. all i have done to it was put on a CAI. everything else is stock.
Old May 9, 2009 | 10:45 AM
Johnboy12358's Avatar
ngk bkr7e (1 range colder from stock)
they changed the part number but i dont know what it is... And if you only have a cai, and aren't planning on anything else, go with ngk bkr6e (stock heat range)
Old May 9, 2009 | 10:57 AM
steddy2112's Avatar
WHy would you run a range colder when he is essentially stock?
Old May 9, 2009 | 01:08 PM
Karlen89's Avatar
I'm changing my plugs next week, any idea on what the new part # is for the bkr7e's are?
Old May 9, 2009 | 02:21 PM
RednBlack's Avatar
i looked locally everwhere for the ngk plugs ended up jus ordering from ottp
Old May 9, 2009 | 02:23 PM
D4u2s0t's Avatar
you wouldn't. people just like to repeat what someone else said, not knowing why they're actually saying it.
like said, if you're planning on not doing anything else, just stick with the stockers. spark plugs are cheap too, so if you start modding and need new plugs down the road it's not a big deal. they're like 2-3 dollars a piece
Old May 9, 2009 | 04:16 PM
dannysauer's Avatar
when should you change to the 2 step colder plugs
Old May 9, 2009 | 05:17 PM
Karlen89's Avatar
Stage 5.4719'er
Old May 9, 2009 | 08:38 PM
Dainslaif's Avatar
Probably never unless you're running at TVS at max boost. Even then I still wouldn't.
Old May 9, 2009 | 08:40 PM
Black SS/SC 06's Avatar
Smartest thing Steddy has ever said
Old May 10, 2009 | 01:28 AM
rocketrex's Avatar
ok well what u guys think about mine? look at my sig thanks
Old May 10, 2009 | 02:27 AM
Dainslaif's Avatar
What size pulley?
Old May 10, 2009 | 02:15 PM
rocketrex's Avatar
2.9in
Old May 10, 2009 | 02:19 PM
BLAZIN07SS's Avatar
I'm too JDM for you
4664 is the new number. they can cross reference it with the old number of 6097 just in case
Old May 10, 2009 | 02:42 PM
steddy2112's Avatar
Har har har
Smart enough to know your drilled and slotted rotors are a waste of money with their less surface area too.
Oh and red painted calipers add stopping power. I need to get round tuit.
At least you're smart enough ***** to use OTTP parts.
Don't be a dick, I can be a bigger one, trust me.
Old May 11, 2009 | 03:31 AM
Dainslaif's Avatar
Originally Posted by rocketrex
2.9in
BKR7Es at .036-.037
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
