spark plugs??
Old Apr 25, 2007 | 03:33 PM
cpraider12's Avatar
spark plugs??
hey guys i was wondering for the ones who are running a 2.6" pulley and 60#s wut kind of spark plugs are u using??
im thinking bout using the ngk ones
Old Apr 25, 2007 | 05:25 PM
saunders1986's Avatar
ngk = crap...........zex FTW
Old Apr 25, 2007 | 05:35 PM
martinsmu's Avatar
NGK are crapp man... jesus
Iam going back to stock pluggs for my setup.
Old Apr 25, 2007 | 05:51 PM
TommySSSC's Avatar
get step 2 colder plugs (.35 gap) in the ngk plugs.. spark plugs are all the the same, most people prefer ngk
Old Apr 26, 2007 | 12:55 AM
cpraider12's Avatar
sweet thanks guys
is there like a certain number that the ngks have?? or part number i can look up by??
Old Apr 26, 2007 | 01:25 AM
dont buy ngks.....trust me zex.......... ask around everyone hates ngks, and loves zex.....82003-4
Old Apr 26, 2007 | 02:06 AM
CobaltSS313's Avatar
zex suck you cant regap them, i switched to ngk, get copper, iridiums are garbage, i ngk only makes 1 step colder in copper, the part number is BKR7E, unless someone can someone knows if they make a 2 step colder plug in with a copper core.
Old Apr 26, 2007 | 02:27 AM
martinsmu's Avatar
how's about we just keep the stock pluggs eh? hahaha everyone seem to have beef for each pluggs..
Old Apr 28, 2007 | 12:25 AM
exiged's Avatar
dont mean to hijack but maybe someone could explain or show me a link?....
Why would you need to ignite 1 or 2 steps colder? what exactly does it do / effect?
I have a 2.2 and maybe will use n20, and down the line sometime will be boosted. I have a set of -1 ngk plugs, What would happen if i put them in now? or should i just wait; whats the point?
Old Apr 28, 2007 | 01:02 AM
RA071623's Avatar
I use a set of BKR7E Copper Core NGK plugs gapped at 35 with no issues.
Old Apr 28, 2007 | 01:04 AM
KillerBee's Avatar
My dealer reccomended me NGK for 1 step colder plugs so i aint complaining and i have not had no trouble out of them and they seem to work better then stock plugs
Old Apr 28, 2007 | 01:09 AM
zsk8er16's Avatar
Zex!!!
Old Apr 28, 2007 | 01:13 AM
burntorange's Avatar
when they refer to the plugs being colder they are talking about more heat being transfered from the plug to the head through more contact to the head and there is ceramic around the center electrode that helps disapate heat. and the smaller gap keeps the fast flowing air rushing into the combustion chamber from "blowing out the spark". Because trying to blow up air fuel mixture without a spark doesn't work well. The reason for the colder plugs is because a by product of compressing air is heat, generated from friction, (which is caused by the air molecules being so close to one another, from being compressed) and heat is an internal combustion's worst enemy...to an extent....and performance enthusiasts' worst problem. And we all know that the more air you cram into the combustion chamber the greater power it will yield. Well, eventually the plugs get heat soaked, much like our superchargers do and begin to act sort of like glow plugs, in diesel vehicles, look up info on them if you don't know, and you start to predetonate, which is igniting the air fuel mixture before the piston reaches the perfect/optimum time @ top dead center, thusly reducing power output. Eventually you can damage something and cause a world of hurt for yourself. So it is wise to run the correct plugs. And as for the debate on which brand of plugs to use, NGK's are perfectly fine. They have a long history of racing/ highperformace applications and I am running Iridiums. Zex is also a very reputable company, either or should be sufficient. As long as you run the correct gap and plug number you should not run into a problems. Feel free to post up any other questions. I am a plethera of knowledge and love to enlighten fellow enthusiasts. Thanks for reading.
KillerBee's Avatar
Hey not putting down Zex but was there not a thread about those plugs messing up engines i could be wrong and you cant gap them please correct me if i am wrong
Old Apr 28, 2007 | 01:35 AM
Mikey851's Avatar
Actually, the reason why you gap plugs smaller is because the higher the heat in the combustion chamber the higher the resistance, not because the air will "blow out the spark". Also, the optimum time to ignite the fuel mixture is not at top dead center but slightly before so that the fuel is expanding fully by the time the cylinder is on it's way down.
Edit: The rest of the info is good; I was just giving you a hard time because anytime someone types that they are a plethora of knowledge and mispells it (Plethera) it's funny.
Old Apr 28, 2007 | 01:43 AM
there was like one post about bad zex plugs, and even than it was just one, every now and than a bad plug will happen with every brand..... just the way it goes...... the zex plugs are pre gapped so you dont have to do it.
Old Apr 28, 2007 | 09:57 AM
KillerBee's Avatar
Yeah i was not sure but yeah your right there is one in every brand thanks for clearing that up
Old Apr 28, 2007 | 10:33 AM
QuikSilverSS's Avatar
Trust me I have both the NGK BKR7E's gapped at 0.040 and 0.035 and also have the ZEX plugs. I can tell you for sure the ZEX plugs are way better. You dont need to gap them, they are already pre gapped for turbo, supercharger and NO2 applications. There was only one post that had a pic of a bad ZEX plug, most people that have had both agree that the ZEX are way better. I run 17.5psi and have had 0 issues with them and can tell you for sure that the car runs way better than with the BKR7E's. Most people who swear by the BKR7E's have never had the ZEX plugs so they cant be sure. Either way the BKR7E's gapped right are good plugs but the ZEX ones are better period!!!
The ZEX Plugs are copper plugs not irriduim by the way
Last edited by QuikSilverSS; Apr 28, 2007 at 10:33 AM. Reason: Automerged Doublepost
Old Apr 28, 2007 | 10:35 PM
Talking Great edit man!
lol, yeah thanks for the extra help man. I mess up REALLY easily when I get on my soap box. lol Oh, and just to mess with you, in a completely friendly way (so please don't get offended.), you misspelled misspells....lol just throwing it out there man. But yeah, you are absolutely correct about the hotter air making it difficult for the spark to jump. But I also believe that you can blow it out....to an extent.. and the tdc thing, COMPLETELY TRUE. I don't know what got into me. I guess just wasn't thinking. Great edit man. Need to learn from mistakes, and then they are worth while.
Old Apr 29, 2007 | 12:41 AM
NapaGuy's Avatar
OEM Plugs are NGK.....
Old Apr 29, 2007 | 12:44 AM
tonylee232's Avatar
i heard stock plugs arae already iridium plugs...the best...
Old Apr 29, 2007 | 01:18 AM
NapaGuy's Avatar
yes they are iridium and offer better efficiency and spark kernel then copper not to mention fuel mileage and they last longer then copper.
Old Apr 29, 2007 | 02:57 AM
Mikey851's Avatar
Haha, you're right, I did misspell..... haha. I think that's even worse.
Old Apr 29, 2007 | 06:53 PM
Talking it all good man.
it is all good man. just fun and games. lol
Old Apr 29, 2007 | 11:53 PM
MTLSSSC's Avatar
what do you guys think about the rapid fire spark plugs from AC Delco?
