SPDDMN's Winter build/Projects
Old Jan 18, 2014 | 10:31 PM
  #201
ThexGovenor's Avatar
did you end up picking up HPT?
Old Jan 18, 2014 | 10:33 PM
  #202
SPDDMN36's Avatar
Not yet. My brothers going half with me and I'm going to his house monday to install the coils on his car. So ill get his half then and order it that night.
Old Jan 18, 2014 | 10:35 PM
  #203
make sure to get the pro
Old Jan 18, 2014 | 10:48 PM
  #204
SPDDMN36's Avatar
I will for sure. Then I need to call glowshift for the cable.
I spent big on my gfs birthday so she was all "go buy something for yourself now." All I could do was laugh knowing that I already have haha.
Old Jan 19, 2014 | 02:36 AM
  #205
Legion's Avatar
Originally Posted by SPDDMN36
And that's where the questions come in. I know a lot depends on what injectors I run and as I tune ill have to go from there.
Why return style?
Old Jan 19, 2014 | 02:41 AM
  #206
Return style is better
Old Jan 19, 2014 | 03:00 AM
  #207
SPDDMN36's Avatar
Consistent flow thru all injectors. At high revs the 4th and sometimes 3rd cylinders can get starved because the proper amount of fuel doesnt have the chance to get there. By opening the end of the fuel rail with a return style you can better fuel supply.
Old Jan 19, 2014 | 09:37 AM
  #208
armcclure's Avatar
And you heard that where?
Old Jan 19, 2014 | 10:22 AM
  #209
TStone's Avatar
oh wow
Old Jan 19, 2014 | 11:42 AM
  #210
SPDDMN36's Avatar
https://www.cobaltss.net/forums/showthread.php?t=217546
Old Jan 19, 2014 | 11:46 AM
  #211
TStone's Avatar
That would require a dinky pump and some huge ass injectors...
You would probably have to get a smaller (not physically, but one that flows less) than stock pump to make that happen..
Old Jan 19, 2014 | 11:54 AM
  #212
SPDDMN36's Avatar
That's just what I've seen on here. I just knew it was something I needed.
Old Jan 19, 2014 | 12:10 PM
  #213
Originally Posted by ThexGovenor
I run 50. With 80# Dont run out of fuel all the way to 7500 fwiw.
Heads up though. Im at 98% IDC at that point so I may bump it up 5 psi or so.
Old Jan 19, 2014 | 12:54 PM
  #214
SPDDMN36's Avatar
That's just what I gathered on here.
Old Jan 19, 2014 | 12:56 PM
  #215
SPDDMN36's Avatar
Noted. Did you base yours on 80# @ 43.5psi and go from there? Or did you start a little higher?
Old Jan 19, 2014 | 01:44 PM
  #216
mrbelvedere's Avatar
the car has a return line stock just not conventional
Old Jan 19, 2014 | 01:53 PM
  #217
I started at 50 psi. I would recommend starting there, since your build will be similar to mine. Just make sure to tune the Return style correctly. Keep in mind at 50 psi the injectors flow more like 92 lb/hr injectors. So set the flow rate multiplier x injector flow rate to equal 92. You also have to keep the injector flow rate below 63.5
Old Jan 19, 2014 | 02:57 PM
  #218
armcclure's Avatar
The flow rate multiplier doesn't work. It's been proven several times. Just set it at 63.5 and scale the maf. And cyl vol if you're using ve.
Old Jan 19, 2014 | 03:07 PM
  #219
Can you elaborate on what you mean by scaling the cylinder volume?
Old Jan 20, 2014 | 08:22 AM
  #220
armcclure's Avatar
Set ifr vs volts back to 1.
Take your actual ifr and find what percentage gets it to 63.5.
Multiply your maf by that %. Then, multiply cyl vol by that percent as well. This scales your ve tables.
Pull your timing way back and start tuning. Your g/cyl at wot will be a bit lower then before.
Also, sometimes it helps to start with a stock maf curve especially if you previously had your injectors set up with the ifr vs volts.
Old Jan 24, 2014 | 05:42 PM
  #221
SPDDMN36's Avatar
Head is on its way back to me and I just picked up a set of the fabled gmr cams and bates solid lifters from OTTP.
Old Jan 24, 2014 | 06:24 PM
  #222
Thought you were going to get the stage 4 cams?
Old Jan 24, 2014 | 06:33 PM
  #223
get your wallet out you also need longer valves and a machinist that knows how to setup the solid lash adj
Old Jan 24, 2014 | 06:55 PM
  #224
SPDDMN36's Avatar
Got a good deal on these. Depending on how much we're talking to get these set up, i may end up going that route.
Old Jan 24, 2014 | 06:59 PM
  #225
SPDDMN36's Avatar
I need to do a bit more reading and talk to you about both of those.
