spraying meth with wotbox
Old Jul 27, 2011 | 12:16 AM
dumpleRL's Avatar
I sorry if this has been discussed, delete if so.
So I was looking at the wotbox app window and saw that it allows for nitrous spraying. That got me thinking i want to run Meth, and the one has a wotbox that has the ability to spray Meth or nitro( how its designed) at xxxx rpm to xxxx rpm. can you set conditions in hpt to make the car ready for the introduction of Meth at the specified rpm range?
( rookie tuning/hpt stuff)
Old Aug 7, 2011 | 10:24 PM
dumpleRL's Avatar
any insight?
Old Aug 8, 2011 | 12:01 PM
TiE2000's Avatar
I'm new at this as well... and I just got done installing my meth kit... this is how it was told to me... so sorry if I'm incorrect.
The meth kit has a controller that you can set so that it only sprays when you boost... it does this by tapping into a MAF wire running xx voltage. (I can't remmeber the voltage right now) Basicly as you boost that voltage goes up... thus telling your controller to start spraying... mine is currently set to do a half spray at 2lbs of boost then a full spray at 5lbs of boost.
EDIT: Sorry i just reread your post... my answer has nothing to do with what you asking. sorry... I can't answer that for you.
Old Aug 8, 2011 | 04:58 PM
dumpleRL's Avatar
its cool i guess id use the wot box as the controller
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
