Squealing problem?
Old Aug 29, 2012 | 06:56 PM
CobaltSS89's Avatar
Squealing problem?
I've changed out the belt and its still doing it(under acceleration also between 0lbs-5-lbs of boost, and it does sound like a pig), i'm thinking it might be the bearings somewhere, or possibly in need of supercharger oil or changing it maybe? I've looked up other topics people have posted on this but i figured i'd pin point it exactly to whats wrong lol. thanks again for your feedback.
Old Aug 31, 2012 | 09:11 AM
CobaltSS89's Avatar
Anyone with this problem, or ever had it before?
Old Aug 31, 2012 | 01:57 PM
SCcobaltSS's Avatar
What happens if you go above 0-5 psi? Could it be a vacuum/boost leak? When my intake manifold wasnt fully seals it would make a sound like that. It was ear piercing.
Old Sep 9, 2012 | 10:24 PM
CobaltSS89's Avatar
it sounds horrible and yeah it is ear piercing for sure, and it still makes the same sound even past 5 psi
Old Sep 9, 2012 | 10:28 PM
rivaladore's Avatar
What size pulley are you running and what belt? Also a possibility that your tensioner's shock is shot.
Old Sep 9, 2012 | 10:32 PM
CobaltSS89's Avatar
2.8 and a stg 2 belt no adjustable tensioner pulley or over sized either. changed the belt still doing it, my tuner said it could possibly be time to change the sc oil, every 100k miles im at 108k now
Old Sep 10, 2012 | 10:32 AM
SCcobaltSS's Avatar
Squealing doesnt sound like old oil to me but who knows. Also when my intake manifold gasket was shot my car would make a terrible squealing sound when on the gas. I changed the gasket and it went away. Just a thought.
Old Sep 10, 2012 | 08:13 PM
CobaltSS89's Avatar
How would i check that? Also update today on my home i got on it a little bit in 3 gear and at about 5k rpms it started to just come to a stsnd still wouldnt go any higher, then i looked at my boost gauge and it went from 15lbs to 20 fast. Never has done this before
Old Sep 11, 2012 | 01:44 AM
rivaladore's Avatar
Your boosting 20psi? Do you have a cat? Could be clogged.
Old Sep 11, 2012 | 02:27 PM
Tjolley's Avatar
I thought gm sayed to change it every 30k
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
