sqweak with new pulley
Old Oct 30, 2009 | 02:23 PM
plaxton's Avatar
i just recently put on a 2.85 pulley and now i notice a loud sqweak coming from the belt below 1700 rpms. but when i give it some gas the sweak goes away.
any ideas what this could be?
the pulley is on a stg 2 style hub if that helps any
Old Oct 30, 2009 | 02:28 PM
c0ld29's Avatar
did you pop the hood and look at it while it was idling? Make sure everything is fit back right, like new pulley is tight, belt is snug, belt is aligned, etc.
Old Oct 30, 2009 | 02:29 PM
arkkornkid's Avatar
sounds like your belt tensioner isn't putting enough pressure on the belt.... might try prying it up a little and see if that takes care of it.
I know my belt would actually slip a little when I went down to a 2.85
also, since you're running GM S2 tune, you might want to go up in size during the colder months anyway.... a 3.0 would probably run better
Old Oct 30, 2009 | 02:33 PM
plaxton's Avatar
thanks for the ideas guys. i will certainly take a look at the tensioner. if that does not fix it i will go back to stock stg 2 pulley.
Old Oct 30, 2009 | 02:36 PM
Rippin07's Avatar
make sure the belt is on all the ribs properly on the AC compressor down low, not uncommon for it to slip off to the inside and cause a squeek and sometimes a squeel.
Old Oct 30, 2009 | 02:39 PM
damien's Avatar
This happened to me next thing I knew after 30mi drive the belt shredded.
Old Oct 30, 2009 | 04:38 PM
plaxton's Avatar
wow. i will have to certainly check that out. i can have that happening to me.
the belt was off my 1 notch. i never would have though of that. thanks for the help guys
Old Oct 30, 2009 | 04:40 PM
ShortStack's Avatar
You could have possibly have the belt off one rib... this happened to me then it started sqeaking all the time, then the belt ripped... found out it was off one rib by the ac condenser.
Edit: Never mind lol.
Old Oct 30, 2009 | 04:50 PM
plaxton's Avatar
thats exactly what it was down by the crank pulley it was off.
Old Oct 30, 2009 | 05:11 PM
damien's Avatar
Mine sqeaks a bit as the car warms up, everything is on right. I've come to the conclusion its because of A: a worn belt and B: my tensioner pulley is all effd up.
Old Oct 30, 2009 | 08:09 PM
plaxton's Avatar
i wondered about that as well. its the original belt. so maybe the belt.
Old Oct 30, 2009 | 08:19 PM
damien's Avatar
You have the GM kit, you should also have the belt.
Old Oct 30, 2009 | 08:22 PM
plaxton's Avatar
original stg2 belt. stg2 was put on only 1 week after i bough the car
Old Oct 30, 2009 | 11:46 PM
cli3e0339384398jk's Avatar
i did the exaxct same thing, was like oh **** what did i wreck then found it was off one rib.
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
