SS/SC on the bottle, where do you spray??
As the title states, if you are spraying your 2.0 SS, where are you putting the nozzle? I have to make a spacer plate or something this week, either one for the TB, under the SC, something. Just wondering where people are putting thiers. I think it would be better to spray after the blower for max cooling, but that is also the biggest pain in the ass due to needing a second gasket ($30) and a spacer for the bypass. Thanks for your help!
Joe
Joe
spraying before would cool the blower down spraying after would give you a cooler intake charge.
most common is the tb spacer or the s/c spacer
Don't hold this as fact but I believe after the blower is better do to the fact that if you spray before the blower it will eat a coating off of the rotor. I believe I read something about this but I don't know from first hand experience.
I think this is it Joe
CA PHENOLIC THROTTLEBODY SPACER
CA Phenolic Throttle body spacer. This spacer is made in house from 1/2" Phenolic material . This spacer will keep your throttle body isolated from heat from the supercharger. It's main purpose as intended is for a place to mount a methanol jet or nitrous jet. By placing the jets before the supercharger , it helps cool the supercharger down and still inject the fluids/ gases into the engine . Thus giving a greater benefit than just injecting them after the supercharger. Spacer comes non-tapped with no holes drilled !!! If you would like it tapped for the Snow performance methanol kit it is an additonal $10.00 fee purchased seperately!!! Comes with longer throttle body bolts , and gasket sealer.
http://cobalt-addiction.com/performance.htm
Jose
