SS/SC problems 8 codes
Old Aug 21, 2013 | 05:09 PM
Eds06Cobaltss's Avatar
Hi, I went to do a turbo swap, then took everything back off and put the supercharger back on, now my car is going into reduced power mode and has 8 cel's they are p0068, p0069, p0121, p1101, p1182, p1183, p2229, p0621. Any ideas? everything is plugged in to the proper place and all vitals are normal until the car acts up. Before I took off my supercharger I had no codes
Old Aug 21, 2013 | 06:47 PM
Bass_Waves's Avatar
Did you change your tune on the ecm?
Old Aug 22, 2013 | 09:23 AM
mrbelvedere's Avatar
cant help if you don't post the code definition which is found here in problems and service https://www.cobaltss.net/forums/prob...-merged-12015/ same section this post should be in
Old Aug 22, 2013 | 12:32 PM
I did not change the tune, and the codes are
P0068 - mani absolute pressure / MAF - throttle position correlation
p0069 - mani absolute pressure - baro pressure correlation
p0121 - TPS / Switch a circuit/ performance problem
p1101 - intake air flow system performance
p1182 - sc pressure sensor performance
p1183 - Inlet pressure sensor code low voltage
p2229 - baro pressure sensor circuit high voltage
p0621 - Generator l-terminal circuit
Old Aug 22, 2013 | 12:44 PM
blueLNFftw's Avatar
So you intalled a stock supercharger set up onto a car that was tune to be turbo, did not retune the car, and are wondering why you have codes?
Retune the car for what you did to it......
Old Aug 22, 2013 | 05:04 PM
No, I installed the cars stock parts (supercharged). The car was tuned for being supercharged not turbo. and when I install my stock parts back on, it freaked out.
Old Aug 22, 2013 | 05:06 PM
I was going to do the turbo swap and ran into problems and had to revert to stock, now its giving all these codes that were not there before
Old Aug 22, 2013 | 05:27 PM
try clearing them out
Old Aug 22, 2013 | 05:31 PM
Bass_Waves's Avatar
Did u unplug the battery before blowing fuses?
Old Aug 22, 2013 | 11:04 PM
I did clear out all the dtcs and they all came back first was a hidden p0069 then light came on with p2229 the rest then fallow, No fuzes are blown, sensors are all clean and were all fine two weeks ago (last time it was used)
turbochargedss2012
Sep 20, 2023 12:17 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
