SS/SC Question
Old Oct 18, 2007 | 03:35 PM
Zekdemos's Avatar
SS/SC Question
Wondering what way is the best way to go. I am going to be putting a smaller pulley on my SC but wondering if its better to go with the GMPP stage 2 or make my own kit. I know im going to be going lower than the 3" im thinking 2.55 or 2.5 just wondering what you guys think the best way to go is?
Old Oct 18, 2007 | 03:38 PM
D4u2s0t's Avatar
well, don't go with a stage 2 because you will need a new tune and you're ditching the pulley anyways. if you go that small make sure you have plenty of cooling mods or don't expect your engine to last.
Old Oct 18, 2007 | 03:39 PM
CobaltVenomSS's Avatar
ALOT!!!! of cooling mods
quadracer0387's Avatar
Originally Posted by Zekdemos
Wondering what way is the best way to go. I am going to be putting a smaller pulley on my SC but wondering if its better to go with the GMPP stage 2 or make my own kit. I know im going to be going lower than the 3" im think 2.55 or 2.5 just wondering what you guys think the best way to go is?
custom kit.... much cheaper... personally i would not go under a 2.6 pully but if you go under a 2.8 you will need alot of cooling mods to be safe
i recomend 2.8, 60 lb injectors, stage 2 belt and custom tune
Old Oct 18, 2007 | 03:41 PM
ColeJJones's Avatar
Bannned
just buy a gm stage 1 and get a smaller pulley
RuSSo-29's Avatar
how small of a pully is the GM stg 2 belt good for?
Old Oct 18, 2007 | 03:42 PM
Zekdemos's Avatar
ok so saying i stay with the 2.6 what cooling mods do you recomend?
Old Oct 18, 2007 | 03:44 PM
cobra heat exchanger, meth
Old Oct 18, 2007 | 03:45 PM
ColeJJones's Avatar
Bannned
i think anything below a 2.8 you need a belt tentioner.. i know intense sells one
Old Oct 18, 2007 | 03:53 PM
Onyxd04Redline's Avatar
60/50's
2.8"
HPT
Enjoy
Old Oct 18, 2007 | 03:56 PM
Zekdemos's Avatar
so you guys recomend staying with about a 2.8 and running 60lb's? and running meth in the intercooler? just trying to clairify
Old Oct 18, 2007 | 04:01 PM
I'm running 50's with the 2.8" and no meth.
Old Oct 18, 2007 | 04:11 PM
Zekdemos's Avatar
another question the meth kit is it meth injection? if so how does that cool the air that would be more of a boost.
Old Oct 18, 2007 | 04:16 PM
JRelly's Avatar
2.8 60lbs GM stage 2 belt custom tune
Cooling mods would be ideal but not a must with this setup
Old Oct 18, 2007 | 04:51 PM
Area47's Avatar
Rent me! per hour
nope.
wrong.
one must learn magic.
Old Oct 18, 2007 | 11:14 PM
tlax23's Avatar
60lbers, tune, 2.8, heat exchanger, dual pass, intake, header, exhaust, poly tranny mounts
Old Oct 18, 2007 | 11:18 PM
WSFrazier's Avatar
Cooling mods are over rated. Not needed, but recommended. I only recently got the Meth. Not saying they don't help, but you car will be fine without them.
Plenty of locals running 2.5 pulleys with no supporting mods, they have been running fine for over a year now.
Old Nov 6, 2007 | 08:04 AM
QuikSilverSS's Avatar
Stick with a 2.8" pulley and hub, 60lb injectors, a good tune, plus a Cold Air intake to make that supercharger whine!
Old Apr 27, 2008 | 03:30 AM
stryder's Avatar
Originally Posted by Area47
nope.
wrong.
preach on then, teach us the ways of said magic.
Old Apr 27, 2008 | 02:18 PM
jimmyfoxx's Avatar
where to you get 50# injectors?
Old Apr 27, 2008 | 03:21 PM
rico's Avatar
okay, so i been thinking of getting dual pass with option b and maybe a cobra or cx racing h/e for cooling mods. then stage 2 and put a 2.8 pulley on it. will that be the right way to go? or do i just like buy just a stage 2 belt and smaller pulley and maybe some injectors, im new at this so any help and diff opinions will help
Old Apr 27, 2008 | 03:23 PM
TommySSSC's Avatar
get a 2.6 when you go to the track, i personally keep my 2.6 on for the summer and switch to my 2.9 out of season
Old Apr 27, 2008 | 03:39 PM
krazycobalt's Avatar
Well if you put ur own stage kit together, it is goign to be cheap but then your are void warenty. If you go with a stg.2 you know what ur getting with the tune and you keep ur GM waranty
Old Apr 27, 2008 | 03:47 PM
Perfect.disguise's Avatar
How much faster would a ss with a 2.6 and 60s be than a stage 2 with a 2.8?
Old Apr 27, 2008 | 04:08 PM
RA071623's Avatar
Well I have a 2.7 and 60's and I just last week got a second H/E hooked up.
