Stage 1 Flash
Stage 1 Flash
Does anyone know how much the dealership would charge just to do a stage 1 flash?The reason i ask is wouldn't it be cheaper if you could get the 42lb injectors cheap somewhere and have the dealership do the stage 1 flash?
NO! You need the authorization code from the Stage Kit inorder for GM to update their system to calibrate your VIN # with the new program or give you a VCI # to access the program through GM TIS.
ok so I did SOME research and I noticed that the stage one bumps you up to 236 hp and the stage 2 bumbs you up to 241. does that sound right? was I right about the injectors being diff. for stage 1 and stage 2? if there the same wouldnt it be cheaper to just buy the pulley and belt to upgrade to stage 2?
same injectors for both stages. All Stage 2 does is swap out the pulley. If I recall correctly it's the same tune as well.
So yes, it is cheaper to just buy stage 1 and get a smaller pulley.
It should be noted however that the GM stage 2 hub is a bitch to get off, if you ever want to go smaller then a 2.8.
If you want, you can spend $400+ for stage one, or, you can buy injectors for $200, a harness for I think it's around $50 (my friends and I just kinda gives these away once we move on) A 2.5 or 2.6 inch pulley and hub for $100, and get a tune from someone ($100-$300, depending on who will do it.) and run mid 13s.
Then again, for the warranty fans, the gm stage 1 is the way to go. Just expensive.
